- Feb 21, 2006
- Dallas TX.
Soft Menu on NF7S v2.0 setting FSB and multi wrong. 1100, 100mhz x11.
Also when I push the power button, the computer doesnt shut down. It just restarts.
Has been running stable for 3 years at - 200mhz, x11, 1.675v. 45c full load.
Anything I change in BIOS and save works, except FSB & multi settings in Soft Menu. This just started out of the blue.
I have unplugged the PSU, pushed the power button, pulled the CMOS bat, set jumper to reset, let set for 10 minutes, put bat back in, reset jumper, powered back up, set to optimized in BIOS ten times now and that doesnt work. Still showing & running at 1100, 100mhz x11.
New CMOS bat, installed new chip drivers, flashed new bios - d27. No dice. Also tested proc in another board and checked out good.
Hope something will fix. Was playing CSS, CZ, 1942, BF2, Oblivion, no problem.
Any ideas?
NF7S v2.0, 2500 Barton, TT Volcano 7+, 2x512 Mushkin dual channel, 2.5,3,3,11, 9800pro 256, Antec Neo 480, 2X WD-120, XP Home.
Any ideas?
