Can't get 9800np to 9800pro speeds!
ap673
I am using an ATI 9800np with a R350 core, 8 pipelines, and 256-bit Infineon Memory on it. All the cooling is stock, and I have a PCI blower under it. I'm using ATI Tool to overclock. So far i've maxed out at core390, mem320. I can't even get the memory to stock 9800pro speeds. Are Infineon memory chips able to overclock? Would it help if I flashed with pro BIOS? It already says I have a 9800pro in Windows XP.
I want to get a VGA chipset cooler and some ramsinks so I can go further, or is it just useless with the crap Infineon memory? I'm looking at the Vantec Iceberg 4 that comes with 4 ramsinks as well. Is this good enough? There are about 7 ram chips on the board, but don't I only need to put ramsinks on the top 4? Thanks.
michaelkahl
Indiana/North Dakota
well since it's a non-pro I would assume the mem that was used on it wasn't meant to go at the pro's mem clock speeds...luck of the draw sometimes...sorry dude I don't know what else to tell you
ap673
ap673
Has anyone heard of Infineon 3.0ns memory chips achieving pro speeds?
Gautam
Senior Benchmark Addict
SF Bay Area
Infineon is not flashable, and doesn't get past 330 without heavy modding. Sorry to be the bearer of bad news. :(
