SOMEONE HELP!!!!! I have a cB0 stepping Celeron II 633 running at 791@83mhz bus clock with the default voltage. It runs flawlessly at 83mhz bus, but falters at 100mhz. I have a decently large HSF. Its no Alpha, but its barely warm at 791. I have tried everything in my playbook. I have a tried combination of voltages from stock 1.55v all the way up to 2.05v (im desparate!) , CAS settings 2 and 3, disabling USB support, changing the DRAM refresh rates, removing my Adaptec SCSI card, booting into windows at 83mhz using all of the previously mention voltages, then using SoftFSB to up it to 100 (it locks up immediately). Even with all that, the farthest it ever got was 30 seconds into the Win98 splash screen.The only thing that seems to work is disabling the L2 cache?! With the cache disabled, it'll boot into Windows98 at 950mhz at 2.0 to 2.05v, but only with the CAS set to 3. It wasn't at all stable (locked up after 5 minutes), but it was stable enough to take measurements using WCPUID. Is this odd that it works only without the L2? 950mhz is fun to look at, but completely worthless without the L2. The setup I am running is as follows:
Tyan Tsunami s1846 MoBo with latest BIOS (4/13/00) and fat chipset Heatsink
Celeron 633 cBo stepped/revision 3
Abit Slotket III (using volt. override jumpers on Slotket)
160mb Apacer PC-100 (1-128mb and 1-32mb,
CAS-? [although runs fine at CAS2@83fsb])
ATI Rage Pro AGP
Adaptec AHA-2940au SCSI adapter
ISA LT winmodem
ISA SB awe32
2 Quantum 4900rpm IDE Hdds
Kingston KNE110TX Ethernet
Generic 40x CDROM
Iomega Jaz 1GB SCSI(disconnected)
Sorry I can't supply temps, no o/b hardware monitor.
I made all these attempts with the chassis's side removed at an ambient temp of around 68 farenheit.
I have a few theories:
1. The part of the die that the L2 cache resides on is not properly being cooled because my HSF doesn't quite sit completely flat on the core since it I took it off an AMD K6-2 450, although It sits very close to flat and is using GOBS of thermal compound.
2. The HSF is simply not good enough (although the temp @2.05v@950mhz is not to hot to touch.)
3. Overheating due to a comination of overvoltage and one of the above reasons.
4. Perhaps the stock 3.3v chipset voltage is not enough, although I don't think its very likely.
5. The L2 cache is simply not up to the task and I'm asking to much and I should just quit while Im ahead.
6. My Duron 650@800 is jealous and is conspiring with Satan and Intel to keep my poor Celemine from reaching the 950mhz it was meant to run at.
Personally, I think #6 is the most likely culprit because I have come too close and gone so far only to have the damn thing tucker out at 83mhz FSB. If I had known it was going to give me this much guff, I would have settled for Cele 566@850 PLEASE, ALL YOU OVERCLOCKIN' SAGES OUT THERE MUST HELP ME!!!!!! I promised my bro' that someday his meager Cele633 would outperform my mighty Athlon Jr. 800 (although not by much, hehe!), and I intend to make good on my promise (I hope.)
For all those who read and considered the above hot air, thanx
Dr. Kaiyosan!
(P.S. You gotta help me!!!)
