Cant get my cpu to go any higher help!!
Shadowlid
OK i am overclocking my old AMD Athlon 2100+. The motherboard i have sucks and i can only overclock the fsb. I can go from 133mhz to 165mhz.
Stock it is 1266mhz if i turn it all the way up it goes to 15XX. So this will not do for what i intend to do with it. Is there any programs i can get so i can push it to 3.0ghz or above?
Also if this does not work. What is the cheapest mobo/cpu bundle i can buy so i can get a 3+ghz jump. Im testing out a cooling technique.
I am running windows 2000 on it. The MOBO is a Pcchips M811LU.
If you need anymore info please tell me.
Thanks in advance,
Shadow
bldegle2
Floyd, VA
"Is there any programs i can get so i can push it to 3.0ghz or above............"
nope, but there still is hope.....
phase is about the only way to get the 3gig, maybe....and that is a big maybe...
'Im testing out a cooling technique.'
curious, what cooling technique are u using?
laterzzzz...........
