Purchased a new Gigabyte Motherboard GA-970A-DS3P (rev.2). I know this is a not so new board but I needed the type configuration to replace my other MSI board which took a crap. I needed this board so I could use the same memory (DDR3) and CPU AMD Athion II X4.
My problem is this new Gigabyte Motherboard allowed me to setup Windows 10 Pro then when I rebooted to use the Bios Settings to disable the Audio I click the button and the screen flashed and came back up frozen with no mouse support. When rebooted I push the delete key and the Bios comes up freezes. If power cable is removed for a few hours then plugged back in it will boot to Windows then freeze. Reboot and the Bios create a message with 3 lines:
Load default settings and boot.
Load default settings and reboot.
Bios Settings
You are supposed to double click your choice. It’s a never ending loop.
Is it the Bios or could it be the memory.
Please help if you can.
Thanks
jmzlr
Bios Settings
Thanks
jmzlr
