Well I'm royally ticked off right now because I won this brand spanking new system as follows:
AMD 1.2 GHZ TBird 266 FSB on a GA-7DX motherboard
256 MB PC2100 Ram
IBM ATA100 7200 40.0 GB Hard Drive
Geforce 2 GTS
Now in win2k I cannot get the soundcard (Sound Blaster Live! 5.1 Digital or Hercules Fortissimo II or even the onboard) to work at all. The drivers for all of them install properly (except for the SBLIVE ones which does some weird ****. According to the tech I won it from @ this massive LAN, the soundcard works fine in windows 98 (the SBLIVE that came with it). The onboard soundcard is disabled in the bios and I enabled it to try and get it to work with win2k. Any thoughts on how I can fix it?
steamed,
bryz
256 MB PC2100 Ram
Geforce 2 GTS
steamed,
bryz
