- Oct 13, 2003
- Rockville, MD & Athens, Greece
[email protected][knoppix]$ lsmod
Module Size Used by Not tainted
ext3 64164 0 (autoclean)
jbd 46356 0 (autoclean) [ext3]
autofs4 8756 1 (autoclean)
af_packet 13512 0 (autoclean)
ntfs 50944 1 (autoclean)
msdos 4652 0 (autoclean)
nls_iso8859-1 2876 1 (autoclean)
nls_cp437 4380 0 (autoclean)
soundcore 3428 0 (autoclean)
agpgart 42628 0 (unused)
natsemi 17408 1
emu10k1-gp 1224 0 (unused)
gameport 1404 0 [emu10k1-gp]
serial 51972 0 (autoclean)
pl2303 10392 0 (unused)
usbserial 17628 0 [pl2303]
usb-storage 61280 0
usb-ohci 18184 0 (unused)
usb-uhci 21868 0 (unused)
usbcore 57824 1 [pl2303 usbserial usb-storage usb-ohci usb-uhci]
apm 9768 2
rtc 6972 0 (autoclean)
cloop 8740 2
the driver i need is the emu10k1 as listed above
i type modprobe emu10k1 and i get this :
modprobe emu10k1
/lib/modules/2.4.24-xfs/kernel/drivers/sound/ac97_codec.o: create_module: Operation not permitted
/lib/modules/2.4.24-xfs/kernel/drivers/sound/ac97_codec.o: insmod /lib/modules/2.4.24-xfs/kernel/drivers/sound/ac97_codec.o failed
/lib/modules/2.4.24-xfs/kernel/drivers/sound/ac97_codec.o: insmod emu10k1 failed
as root
modprobe emu10k1
/lib/modules/2.4.24-xfs/kernel/drivers/sound/emu10k1/emu10k1.o: init_module: No such device
Hint: insmod errors can be caused by incorrect module parameters, including invalid IO or IRQ parameters.
You may find more information in syslog or the output from dmesg
/lib/modules/2.4.24-xfs/kernel/drivers/sound/emu10k1/emu10k1.o: insmod /lib/modules/2.4.24-xfs/kernel/drivers/sound/emu10k1/emu10k1.o failed
/lib/modules/2.4.24-xfs/kernel/drivers/sound/emu10k1/emu10k1.o: insmod emu10k1 failed
dmesg
Creative EMU10K1 PCI Audio Driver, version 0.20, 01:17:01 Feb 4 2004
insmod -r emu10k1
Using /lib/modules/2.4.24-xfs/kernel/drivers/sound/emu10k1/emu10k1.o
/lib/modules/2.4.24-xfs/kernel/drivers/sound/emu10k1/emu10k1.o: /lib/modules/2.4.24-xfs/kernel/drivers/sound/emu10k1/emu10k1.o: unresolved symbol sound_unload_mididev
plus at least 20 more simila errors...
Thanks
natsemi 17408 1
usb-storage 61280 0
apm 9768 2
cloop 8740 2
modprobe emu10k1
as root
modprobe emu10k1
dmesg
insmod -r emu10k1
Thanks
