Cant overclock
marc.L
Western Australia
When i had windows 98 on my pc i could overclock the fsb to get my duron 900 up to a bit over 1100 (unstable) or around 1000 stable.
now that i formatted my pc and put on win2k if i change the fsb by 1 point (from 100 to 101) windows comes up with an error before it is loaded and requests me to insert the windows cd...
im not sure what the problem is here so i put this post under 'general hardware'
any help?
Did you install the OS while overclocked?
I think that Win2k is a bit pickier over overclocking.
marc.L said:
pc was not overclocked when i installed new windows. ideas?
Have you changed anything else at all?
Have you tried inserting the CD when asked?
Do you have all the latest drivers?
nothing changed... well i think i may have done some drive partitioning but that couldnt affect it??? i'll have another shot and this time insert the cd and see what happens.
should i set the core coltage to auto-detect (default) or manually to 1.65 or something?
You could try increasing core voltage - 1.65v is default for a duron - try 1.7v. This may make the system more stable.
1.7 eh?
ok and also how do people alter the multiplier??? i was under the impression the soltek was a good overclocker so assumed you could change the multiplier in the bios. so how do people get that option or the the soltek only good for oc'ing the fsb ??
im 100% newbie.
thanks for your assistance also
Multiplier overclocking? OK.
First you need to unlock your CPU. Shut down the PC and take out the processor. Look on the surface of the CPU for tiny gold dots. There should be seven sets. L1, L2 L3, L4, L5, L6 and L7. Look for the L1 ones. Using a sharp pencil join the sets of dots (called bridges). ie:
before
After
Then put the PC back together and reboot. You should now be able to change the multiplier in the BIOS :D
For a better guide, look at the articles at www.overclockers.com
ok i shut down my pc, restarted and changed vcore to 1.675 and fsb to 105
got the same error msg this time i wrote it down its not looking for cd after all...
"the following file is missing or corrupt
<windows root>\system32\ntoskrnl.exe
please reinstall a copy of this file"
or something like that
NT Operating System Kernel?
Overclock your PC (say FSB @ 105MHz) and boot off of your win2k CD - choose to repair your installation.
marc.L said:
no luck...i dunno whats wrong
i guess i'll live with my duron at 900 till i buy my xp2000+ in a while
You could try multiplier overclocking, it will help you gain higher CPU speeds, but will not give as much of a boost to the system as FSB overclocking.
You might have to set a jumper on the board. If you set the BIOS to 101 and the board is strictly 100 there could be an error there. The board should be set to adjust the fsb in bios.
Just a thought. My Iwill hates it when I do anything on the board, it just likes bios tweaking.
