EDIT: Solved: Tertiary timings not set to auto were the problem
Hi!
I'm trying to overclock my PC:
Mobo : P8P67 Deluxe and i7-2600k @ 3.40ghz.
Overclocked BCLK (106.4) and multiplier (42) which gives 4467mhz. LLC is set to high as with medium I have a 0.05V spike when I stop IBT and very high goes beyond values.
I'm using offset voltage, that is +0.015. Under load, VCORE is about 1.31V.
Now, memtest and even an hour of IBT passes without problems, but prime95 with in-place 1440K FFTs almost immediately fails with rounding error (no BSOD). With other FFTs in that range, it may fail in 30 minutes or ine hour.
The same prime95 with small FFTs is fine.
At stock settings, everything is fine. Temperatures are fine too (below 80C).
I've tried setting an offset voltage up to +0.060 (so vcore becomes 1.35V under load), but it didn't change anything (apart from more heat of course).
Now the question (obviously is): Why is it failing?
I overclocked my RAM too, but p95 fails with fft in-place, which don't stress the memory much. Larger FFTs, memtest and IBT don't fail, so I don't think this is related to RAM or IMC.
But this isn't related to the CPU either because upping the voltage doesn't change anything.
Any thoughts? Should I just ignore it and live with that?
Hi!
