I don't have the guts to pry the heatsinks from the graphicscard ram. They are really glued on hard. And that goes for the flat ones made of copper.
The other ones were much easier to remove. Posted som pictures in link below.
I was thinking about glueing the aluminum heatsinks that came in the box with my new cooler onto the copper ones on my hd 4890.
Is it possible to glue aluminum to copper and do I loose much cooling power.
I'm mounting a Arctic Cooling Twin Turbo 2 on my Powercolor hd 4890.
Here is some very big pictures:
My rig without graphicscard. The two 120mm fans in the bottom on intake will help cool the GPU.
Inside of chassi 1
Inside of chassi 2
Powercolor hd 4890 stripped from stock cooler and some of the heatsinks.
AC Twin Turbo 2 without fans in background.
Card stripped 1
Card stripped 2
My rig:
Chassis: Enlight 2F03 Svart mATX
Motherboard: ASRock Z68M-ITX/HT Socket 1155
CPU: Intel® Core I5-2500K 3300MHz
CPU cooler: Arctic Cooling Freezer 7 Pro Rev 2
RAM: G.Skill Ripjaws X Performance - DDR3 1600 Mhz - 2 x 4GB
GPU: Powercolor hd 4890
GPU cooler: Arctic cooling twin turbu 2
Intake fans: 2 pcs. Fractal Design Silent Series 120mm 15dBA
Outtake: Noctua NF-B9 PWM Silent Case 92mm Fan
Inside of chassi 1
Inside of chassi 2
Card stripped 1
Card stripped 2
My rig:
