- Oct 12, 2001
- Los Angeles
IDK WTH is going on, but my main rig can't send these 5 units its got. Here is the log from the first:
and the second:
Code:
[22:16:37] - Ask before connecting: No
[22:16:37] - Use IE connection settings: Yes
[22:16:37] - User name: nikhsub1 (Team 32)
[22:16:37] - User ID: 1C8B105862F0B107
[22:16:37] - Machine ID: 1
[22:16:37]
[22:16:37] Loaded queue successfully.
[22:16:37] + Benchmarking ...
[22:16:41] The benchmark result is 18232
[22:16:41]
[22:16:41] + Processing work unit
[22:16:41] - Autosending finished units...
[22:16:41] Core required: FahCore_78.exe
[22:16:41] Trying to send all finished work units
[22:16:41] Core found.
[22:16:41] + Attempting to send results
[22:16:41] - Reading file work/wuresults_01.dat from core
[22:16:41] (Read 3178409 bytes from disk)
[22:16:41] Working on Unit 05 [December 6 22:16:41]
[22:16:41] + Working ...
[22:16:41] - Calling 'FahCore_78.exe -dir work/ -suffix 05 -checkpoint 30 -service -forceasm -verbose -lifeline 3944 -version 502'
[22:16:41]
[22:16:41] *------------------------------*
[22:16:41] Folding@Home Gromacs Core
[22:16:41] Version 1.90 (March 8, 2006)
[22:16:41]
[22:16:41] Preparing to commence simulation
[22:16:41] - Assembly optimizations manually forced on.
[22:16:41] - Not checking prior termination.
[22:16:42] - Expanded 1574808 -> 8082985 (decompressed 513.2 percent)
[22:16:42]
[22:16:42] Project: 1862 (Run 6, Clone 74, Gen 5)
[22:16:42]
[22:16:42] Assembly optimizations on if available.
[22:16:42] Entering M.D.
[22:17:03] (Starting from checkpoint)
[22:17:03] Protein: p1862_Myosin6_PT_US_TIP3P_bbox
[22:17:03]
[22:17:03] Writing local files
[22:17:03] Completed 320000 out of 500000 steps (64)
[22:17:03] Extra SSE boost OK.
[22:17:12] Couldn't send HTTP request to server (wininet)
[22:17:12] + Could not connect to Work Server (results)
[22:17:12] (171.65.103.162:8080)
[22:17:12] - Error: Could not transmit unit 01 (completed December 1) to work server.
[22:17:12] - 34 failed uploads of this unit.
[22:17:12] + Attempting to send results
[22:17:12] - Reading file work/wuresults_01.dat from core
[22:17:12] (Read 3178409 bytes from disk)
and the second:
Code:
[22:13:18] - Ask before connecting: No
[22:13:18] - Use IE connection settings: Yes
[22:13:18] - User name: nikhsub1 (Team 32)
[22:13:18] - User ID: 1C8B105862F0B107
[22:13:18] - Machine ID: 2
[22:13:18]
[22:13:18] Loaded queue successfully.
[22:13:18] + Benchmarking ...
[22:13:22] The benchmark result is 18388
[22:13:22]
[22:13:22] - Autosending finished units...
[22:13:22] + Processing work unit
[22:13:22] Trying to send all finished work units
[22:13:22] Core required: FahCore_82.exe
[22:13:22] + Attempting to send results
[22:13:22] - Reading file work/wuresults_02.dat from core
[22:13:22] Core found.
[22:13:22] (Read 2543290 bytes from disk)
[22:13:22] Working on Unit 05 [December 6 22:13:22]
[22:13:22] + Working ...
[22:13:22] - Calling 'FahCore_82.exe -dir work/ -suffix 05 -checkpoint 30 -service -forceasm -verbose -lifeline 1848 -version 502'
[22:13:22]
[22:13:22] *------------------------------*
[22:13:22] Folding@Home PMD Core
[22:13:22] Version 1.03 (September 7, 2005)
[22:13:22]
[22:13:22] Preparing to commence simulation
[22:13:22] - Assembly optimizations manually forced on.
[22:13:22] - Not checking prior termination.
[22:13:22] - Expanded 83682 -> 561874 (decompressed 671.4 percent)
[22:13:22]
[22:13:22] Project: 1808 (Run 14, Clone 446, Gen 89)
[22:13:22]
[22:13:22] Assembly optimizations on if available.
[22:13:22] Entering M.D.
[22:13:53] Couldn't send HTTP request to server (wininet)
[22:13:53] + Could not connect to Work Server (results)
[22:13:53] (171.64.122.136:80)
[22:13:53] - Error: Could not transmit unit 02 (completed December 3) to work server.
[22:13:53] - 24 failed uploads of this unit.
[22:13:53] + Attempting to send results
[22:13:53] - Reading file work/wuresults_02.dat from core
[22:13:53] (Read 2543290 bytes from disk)
[22:14:25] Couldn't send HTTP request to server (wininet)
[22:14:25] + Could not connect to Work Server (results)
[22:14:25] (171.65.103.100:80)
[22:14:25] Could not transmit unit 02 to Collection server; keeping in queue.
[22:14:25] + Attempting to send results
[22:14:25] - Reading file work/wuresults_04.dat from core
[22:14:25] (Read 2653161 bytes from disk)
[22:14:35] Protein: p1808_Collagen_Brodsky_refolding
[22:14:35]
[22:14:35] Completed 205800 out of 500000 steps (41)
[22:14:57] Couldn't send HTTP request to server (wininet)
[22:14:57] + Could not connect to Work Server (results)
[22:14:57] (171.65.103.160:8080)
[22:14:57] - Error: Could not transmit unit 04 (completed December 6) to work server.
[22:14:57] - 6 failed uploads of this unit.
[22:14:57] + Attempting to send results
[22:14:57] - Reading file work/wuresults_04.dat from core
[22:14:57] (Read 2653161 bytes from disk)
[22:14:58] Couldn't send HTTP request to server (wininet)
[22:14:58] + Could not connect to Work Server (results)
[22:14:58] (171.65.103.100:8080)
[22:14:58] Could not transmit unit 04 to Collection server; keeping in queue.
[22:14:58] + Sent 0 of 2 completed units to the server
[22:14:58] - Autosend completed
