ok.. i have prob with my network..
comp 1 using win xp pro
comp 2 using mandrake 9.0
connect wih router..
comp 1 is able to access and transfer file from linux box
but the linux box ..only able to see the shared file on windows...(tried to copy any file from windows but can make it works)
i think this will be setting prob..because i try replace my linux box with another win xp pro and no prob at all
so..does anybody know how to set my linux box..(i am newbie..so detail will be very great)
and just curious..is mandrake 9.0 by default using tcp/ip ??..anyways to uninstall and install them again..
in network group, some people sugest me to use other protoco..but don't know how to set in mandrake
