April 2015 servicing stack update for Windows 7 and Windows Server 2008 R2 (KB3020369) and then the 'SP2'' from #18.
Check WU, if it gets stuck, use the Dalai/krelay 'fix'.
I have and I remember why I stopped using it. Wsus is a lot more comprehensive. The cab file is in wsus's folder btw.
I just ran into the not-updating thing on a Windows 7 laptop. It had the recent convenience update installed in May, but not updated since then. Starting the MS one I left it running for a few hours before I got bored. Ran a disk cleanup which removes redundant updates, and tried again. Still nothing. Tried WUMT, that did exactly the same as the Windows one in that it took forever to get nowhere. Now I'm trying wsusoffline... at least the downloader is visibly doing something!
For all you Windows 10 haters out there, do you remember the frustration of the broken Windows 7 update? And Windows XP update was badly broken too following SP2. I've had no such problem with Windows 10 so far.
Was that aimed at me, since it was quoting me but I don't see the connection?
Anyway, running wsusoffline now. 1st pass installed a bunch of updates and asked for reboot. 2nd pass just did 13 updates and asking for another reboot. I need to poke around it more since I have no idea what the updates are, nor do I recall having a choice to review each one first.
http://www.infoworld.com/article/30...-replaces-it-with-kb-3172605-and-3172614.html
Found above interesting reading while doing updates, sounds like the writer has also gone though much pain in this...
You should now try the Microsoft update tool, even if WSUSOffline is not done. I found it fixed the brokenness at the front end of the process so that the Windows Update worked just fine the rest of the way. The Windows Update once fixed is faster than WSUSOffline which starts and restarts and still doesn't get all the updates.
As a further update, after the two passes above, no more installs were offered although there were comments to the effect of missing updates. At that point I did the Windows WU and that ran quickly (minutes, not hours) and I could grab a few more there. So, I'm up to date at last.
When you select to just download this August 2016 Update Rollup instead of install it, how large is the download?
https://www.microsoft.com/en-us/download/details.aspx?id=53568
