Been having big problems with my FIC 503+ mb for a while now. Just discovered the problem. A capacitor near the CPU that I bent over so I could install a GORB on my K62 finally broke. I think I can handle soldering in a new one but I have a problem ...
The original capacitor was 6.3v 1500 uF. The only replacement ones I could find were 470 uF, 1000 uF and 2200 uF, all 16v.
Which one should I use? I know the higher voltage isn't an issue. Should I go with the 2200 uF? Is it possible to combine the the 1000 and 470 to get 1470 which I would think is close enough to 1500? If it is possible how should the two capacitors be connected? Series? Parallel? Pos-to-pos & neg-to-neg? I have no idea. TIA.
