Case cooling question
KD
While running prime95 or sisoft sandra with Cpu set at 700Mhz and voltage set at 1.95v my CPU temp is 44c and my MB load temp is 28c, idle temp is 27c. The room temp is about 77°f. I have two 80mm fans in the case, 1 blowing in (front), 1 blowing out (back). Do you think it might lower those temps if I replaced the 80mm with 92mm fans?
Thank you
ASUS CUSL2
P3 700/910 wantabe 945
1x256M PC133
Vantec FCE-6254OD w/delta38
Maxtor30G7200
SBLive, HP CDRW,
Pioneer DVD
