I would think having your air flow in the same general direction would be the most effective method but I see a number of pics showing flow out of the case sides etc. Since heat rises and most PS are mounted in the upper part of the case ultimately the heat will be removed by the ps correct? SO the goal should be to increase air flow through the power supply by creating positive pressure within the case (from the front and or sides) Am I correct in these impressions?
