Case door...
the_par4d0x_
I think I made a boo boo and bought a case that the side didn't come off by itself. The entire top and both sides come off in once piece... I don't know for sure yet but I think so. Do you think it would be possible to modify it so only the one panel comes off? Maybe even make it into a door with hinges and stuff....
Cause I wanan put a duct and fans and a window on the side of my case and it would not be easy to get in and out of the case with all that stuff on there and it having that kind of case.
i'm shure it can be done. but if do it post some pics. I just got a full tower of unknown brand and it is the same as yours and I would like to do the same thing.
I have a case like this too. Its an old modded AT case from my p90 gateway back in 95. I was thinking about How i'd do It, cause its a pain in the --toe-- to get it off.
What case did you get??
I picked up the exact same style of case at a computer fair, except the sides are removable.
How good are you. Can anyone say DELOREAN STYLE!!!!!! Now that would be the Ultimate for a case door. The only question is "can he do it???" Anyways, just a thought. By the way, if you do pull it off you have to post pic's for the rest of us to admire!!!!;)
hehe I was thinking on keeping it low key mod until the doo opens. I dont even want hinges visible.
