- Mar 21, 2002
I'm thinking of installing a std. 80mm case fan in front of my CPU/HS/Fan (blowing toward it) for additional cooling of the heat sink, and consequently, the CPU. (please see attached diagram).
Q. Will this interfere in any way with the original design of the Celeron 400 Slot 1 CPU/HSF arrangement? What about another case fan installed on the side of the case (near the PSU), hanging above the mobo/HS? Will the fact that it would be blowing air across the case interfere with the air flow that is supposed to be directed out the rear of the case (see diagram)?
Any benefit from drilling holes into the bottom of the case, or can they also interfere with the air current that is supposed to be directed out the rear of the case? (Anything I can do to improve cooling without having to buy expensive specialized cooling fans, I'm all for!)
Since my last computer (OC'd 486) was always filled with dust/dirt, I'm also planning on attaching panty hose over the fans and every opening on the computer, as a filter. Can this significantly affect my temps?
