- Aug 4, 2001
- PTBO, ON, CAN
My new full tower case has a spot for two 8 cm at the back above the ps, which is an Enermax EG365P-VE FM 350 W with two fans in it.
I want to use the two spots to install 8 cm exhausts and then put one or two intake in the side panel near the bottom off the case. I've read that it's better to have more air coming out of the case than coming in, so my intake cfm's should be a bit lower than the outgoing, right?
The store I was thinking of buying the fans from sells ThermalTake and Sunon 8 cm's, I am leaning towards the ThermalTakes because they are quieter with a higher cfm rating, if anyone thinks otherwise let me know.
So with the intake, I was going to get two 8 cm or one 120 cm fan, and I am thinking the single fan would be better since I only have to buy one filter and one grill, and it would look a bit better than two.
Lastly, where on the side panel would I want to place the intake fan? Near the bottom I know, but towards the back or front of the case?
I apologize for the long drawn out post, but I want my situtation to be understood. Any comments or suggestions would be appreciated.
Thanks in advance
Thanks in advance
