Case For 45€
McHacken
Rotterdam
witch one is good? first ore second one??
WyrmMaster
I'm a little teapot Senior
Montana, USA
just get a generic case like i did, and then mod the heck out of it. The great thing is you dont feel too bad cuttin holes in a 30 dollar case.
flounder43
Senior Lawyer-clocker
Minneapolis
I would go with the bigger of the two. BTW, I noticed the €, and assume that the other links are meaningless because you are in Europe.
flounder43
Tweaked!
Xtreme refugee
Cincinnati, Oh.
Out of those choices, I'd take the purple (3rd) one in the lower group. But, kinda like WyrmMaster said, you're better off finding a cheap full tower and having at it! Those cases look kinda small? Do they have good ventilation? ;)
Yodums
Senior Member
Ottawa, Canada
The second one would be better, bigger, and better airflow. I would recommend you just picking up a generic full tower, and then mod that sucker.
Yodums
M
McHacken
Rotterdam
hmm , maybe i should buy the second one! but dont need a fulltower becouse its too big and its 70€
