Catalyst 7.8's FUBAR'd my system!
evoke
I upgraded from my 7.7's to the new 7.8's and that's where everything started going wrong!
This is what happened when I booted up after installing the 7.8's.
Notice the lack of icons everywhere and the funky folder and start menu, I didn't try loading a game as my DxDiag results weren't good(more on that later).
Now I'm not sure what effect these settings have, but on all other ATi drivers up to now all the SmartGart settings have all been on, but with the 7.8's most of it's turned off and won't turn back on.
The first time I installed the drivers I just did the usual stuff, that didn't work so I tried driver cleaners, then doing a clean boot to install and so on, no luck with any of it.
I ran a DxDiag to see what was up with the video and I got a host of errors and none of the tests ran correctly. :-/
I'm back with my 7.7's right now and all is good, but I want to use the 7.8's as they have a Bioshock fix I need!
My DxDiag results:
Code:
System Information
Time of this report: 8/20/2007, 21:29:46
       Machine name: GAMER-ONE
   Operating System: Windows XP Professional (5.1, Build 2600) Service Pack 2 (2600.xpsp_sp2_qfe.070227-2300)
           Language: English (Regional Setting: English)
System Manufacturer: P4i6G
       System Model: P4i65G
               BIOS: Default System BIOS
          Processor: Intel(R) Pentium(R) 4 CPU 3.00GHz (2 CPUs)
             Memory: 1022MB RAM
          Page File: 398MB used, 2064MB available
        Windows Dir: C:\WINDOWS
    DirectX Version: DirectX 9.0c (4.09.0000.0904)
DX Setup Parameters: Not found
     DxDiag Version: 5.03.2600.2180 32bit Unicode
DxDiag Notes
  DirectX Files Tab: No problems found.
      Display Tab 1: The file ati2dvag.dll is not digitally signed, which means that it has not been tested by Microsoft's Windows Hardware Quality Labs (WHQL).  You may be able to get a WHQL logo'd driver from the hardware manufacturer. DirectDraw test results: Failure at step 5 (User verification of rectangles): HRESULT = 0x00000000 (error code) Direct3D 7 test results: Failure at step 32 (User verification of Direct3D rendering): HRESULT = 0x00000000 (error code) Direct3D 8 test results: Failure at step 32 (User verification of Direct3D rendering): HRESULT = 0x00000000 (error code) Direct3D 9 test results: Failure at step 32 (User verification of Direct3D rendering): HRESULT = 0x00000000 (error code)
        Sound Tab 1: No problems found.
          Music Tab: No problems found.
          Input Tab: No problems found.
        Network Tab: No problems found.
DirectX Debug Levels
Direct3D:    0/4 (n/a)
DirectDraw:  0/4 (retail)
DirectInput: 0/5 (n/a)
DirectMusic: 0/5 (n/a)
DirectPlay:  0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow:  0/6 (retail)
Display Devices
        Card name: Radeon X1950 Pro
     Manufacturer: ATI Technologies Inc.
        Chip type: ATI Radeon Graphics Processor AGP (0x7280)
         DAC type: Internal DAC(400MHz)
       Device Key: Enum\PCI\VEN_1002&DEV_7280&SUBSYS_E190174B&REV_9A
   Display Memory: 512.0 MB
     Current Mode: 1024 x 768 (32 bit) (85Hz)
          Monitor: Plug and Play Monitor
  Monitor Max Res: 1600,1200
      Driver Name: ati2dvag.dll
   Driver Version: 6.14.0010.6715 (English)
      DDI Version: 9 (or higher)
Driver Attributes: Final Retail
 Driver Date/Size: 8/17/2007 04:09:40, 269312 bytes
      WHQL Logo'd: No
  WHQL Date Stamp: None
              VDD: n/a
         Mini VDD: ati2mtag.sys
    Mini VDD Date: 8/17/2007 04:09:20, 2371584 bytes
Device Identifier: {D7B71EE2-31C0-11CF-C06E-9AC13BC2CB35}
        Vendor ID: 0x1002
        Device ID: 0x7280
        SubSys ID: 0xE190174B
      Revision ID: 0x009A
      Revision ID: 0x009A
      Video Accel:
 Deinterlace Caps: n/a
         Registry: OK
     DDraw Status: Enabled
       D3D Status: Enabled
       AGP Status: Not Available
DDraw Test Result: Failure at step 5 (User verification of rectangles): HRESULT = 0x00000000 (error code)
 D3D7 Test Result: Failure at step 32 (User verification of Direct3D rendering): HRESULT = 0x00000000 (error code)
 D3D8 Test Result: Failure at step 32 (User verification of Direct3D rendering): HRESULT = 0x00000000 (error code)
 D3D9 Test Result: Failure at step 32 (User verification of Direct3D rendering): HRESULT = 0x00000000 (error code)
Sound Devices
            Description: SB Audigy 2 Audio [BC00]
 Default Sound Playback: Yes
 Default Voice Playback: Yes
            Hardware ID: PCI\VEN_1102&DEV_0004&SUBSYS_10031102&REV_04
        Manufacturer ID: 1
             Product ID: 100
                   Type: WDM
            Driver Name: ctaud2k.sys
         Driver Version: 5.12.0001.1196 (English)
            WHQL Logo'd: Yes
          Date and Size: 8/11/2006 14:45:38, 499584 bytes
            Other Files:
        Driver Provider: Creative
         HW Accel Level: Full
              Cap Flags: 0xF5F
    Min/Max Sample Rate: 4000, 192000
Static/Strm HW Mix Bufs: 64, 62
 Static/Strm HW 3D Bufs: 64, 62
              HW Memory: 0
       Voice Management: Yes
 EAX(tm) 2.0 Listen/Src: Yes, Yes
   I3DL2(tm) Listen/Src: No, No
Sensaura(tm) ZoomFX(tm): No
               Registry: OK
      Sound Test Result: Not run
Sound Capture Devices
  Default Sound Capture: Yes
  Default Voice Capture: Yes
              Cap Flags: 0x41
           Format Flags: 0xFFF
DirectMusic
        DLS Path: C:\WINDOWS\SYSTEM32\drivers\GM.DLS
     DLS Version: 1.00.0016.0002
    Acceleration: Enabled
           Ports: SB Audigy 2 DirectMusic Synthesizer [BC00], Hardware (Kernel Mode), Output, DLS, Internal, Default Port
                  SB Audigy 2 Audio [BC00], Software (Kernel Mode), Output, DLS, Internal
                  Microsoft MIDI Mapper [Emulated], Hardware (Not Kernel Mode), Output, No DLS, Internal
                  SB Audigy 2 Synth A [BC00] [Emulated], Hardware (Not Kernel Mode), Output, No DLS, Internal
                  SB Audigy 2 Sw Synth [BC00] [Emulated], Hardware (Not Kernel Mode), Output, No DLS, Internal
                  SB Audigy 2 Synth B [BC00] [Emulated], Hardware (Not Kernel Mode), Output, No DLS, Internal
                  Microsoft GS Wavetable SW Synth [Emulated], Hardware (Not Kernel Mode), Output, No DLS, Internal
                  Microsoft Synthesizer, Software (Not Kernel Mode), Output, DLS, Internal
        Registry: OK
DirectInput Devices
      Device Name: Mouse
         Attached: 1
    Controller ID: n/a
Vendor/Product ID: n/a
        FF Driver: n/a
      Device Name: Keyboard
         Attached: 1
    Controller ID: n/a
        FF Driver: n/a
      Device Name: USB Gaming Keyboard Pro
         Attached: 1
    Controller ID: 0x11
Vendor/Product ID: 0x06A3, 0x8000
        FF Driver: n/a
         Attached: 1
    Controller ID: 0x11
        FF Driver: n/a
         Attached: 1
    Controller ID: 0x11
        FF Driver: n/a
         Attached: 1
    Controller ID: 0x0
        FF Driver: n/a
Poll w/ Interrupt: No
         Registry: OK
USB Devices
+ USB Root Hub
| Vendor/Product ID: 0x8086, 0x24D7
| Matching Device ID: usb\root_hub
| Service: usbhub
| Driver: usbhub.sys, 11/20/2006 09:50:11, 59264 bytes
| Driver: usbd.sys, 8/23/2001 13:00:00, 4736 bytes
Gameport Devices
PS/2 Devices
+ HID Keyboard Device
| Matching Device ID: hid_device_system_keyboard
| Service: kbdhid
| OEMData: 20 00 00 10 0B 00 00 00
| Driver: kbdhid.sys, 8/3/2004 22:58:36, 14848 bytes
| Driver: kbdclass.sys, 8/3/2004 22:58:34, 24576 bytes
+ Terminal Server Keyboard Driver
| Matching Device ID: root\rdp_kbd
| Upper Filters: kbdclass
| Service: TermDD
| Driver: termdd.sys, 8/4/2004 01:01:08, 40840 bytes
+ Microsoft USB IntelliMouse Explorer 3.0 (IntelliPoint)
| Vendor/Product ID: 0x045E, 0x0047
| Matching Device ID: hid\vid_045e&pid_0047
| Upper Filters: Point32
| Service: mouhid
| Driver: mouhid.sys, 8/17/2001 13:48:00, 12160 bytes
| Driver: mouclass.sys, 8/3/2004 22:58:34, 23040 bytes
| Driver: point32.sys, 6/30/2006 09:51:21, 21760 bytes
| Driver: ipcoin8.dll, 7/8/2006 00:10:00, 133952 bytes
+ Terminal Server Mouse Driver
| Matching Device ID: root\rdp_mou
| Upper Filters: mouclass
| Service: TermDD
DirectPlay Service Providers
DirectPlay8 Modem Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.2180)
DirectPlay8 Serial Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.2180)
DirectPlay8 IPX Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.2180)
DirectPlay8 TCP/IP Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.2180)
Internet TCP/IP Connection For DirectPlay - Registry: OK, File: dpwsockx.dll (5.03.2600.2180)
IPX Connection For DirectPlay - Registry: OK, File: dpwsockx.dll (5.03.2600.2180)
Modem Connection For DirectPlay - Registry: OK, File: dpmodemx.dll (5.03.2600.2180)
Serial Connection For DirectPlay - Registry: OK, File: dpmodemx.dll (5.03.2600.2180)
DirectPlay Voice Wizard Tests: Full Duplex: Not run, Half Duplex: Not run, Mic: Not run
DirectPlay Test Result: Not run
Registry: OK
DirectPlay Adapters
DirectPlay8 Serial Service Provider: COM1
DirectPlay8 TCP/IP Service Provider: MS TCP Loopback interface - IPv4 -
DirectPlay Voice Codecs
Voxware VR12 1.4kbit/s
Voxware SC06 6.4kbit/s
Voxware SC03 3.2kbit/s
MS-PCM 64 kbit/s
MS-ADPCM 32.8 kbit/s
Microsoft GSM 6.10 13 kbit/s
TrueSpeech(TM) 8.6 kbit/s
DirectPlay Lobbyable Apps
Disk & DVD/CD-ROM Drives
      Drive: C:
 Free Space: 12.6 GB
Total Space: 117.2 GB
File System: NTFS
      Model: Maxtor 6Y120M0
      Drive: E:
 Free Space: 22.8 GB
Total Space: 76.3 GB
File System: NTFS
      Model: IC35L090AVV207-0
      Drive: D:
      Model: SAMSUNG CDRW/DVD SM-348B
     Driver: c:\windows\system32\drivers\cdrom.sys, 5.01.2600.2180 (English), 8/3/2004 22:59:54, 49536 bytes
      Drive: F:
      Model: YX3231U CRX843K SCSI CdRom Device
System Devices
     Name: Intel(R) 82865G/PE/P/GV/82848P Processor to AGP Controller - 2571
Device ID: PCI\VEN_8086&DEV_2571&SUBSYS_00000000&REV_02\3&267A616A&0&08
   Driver: C:\WINDOWS\system32\DRIVERS\AGP440.SYS, 5.01.2600.2180 (English), 8/4/2004 00:07:42, 42368 bytes
     Name: Intel(R) 82865G/PE/P/GV/82848P Processor to I/O Controller - 2570
Device ID: PCI\VEN_8086&DEV_2570&SUBSYS_00000000&REV_02\3&267A616A&0&00
   Driver: n/a
     Name: Intel(R) 82801EB USB Universal Host Controller - 24DE
Device ID: PCI\VEN_8086&DEV_24DE&SUBSYS_24D01849&REV_02\3&267A616A&0&EB
   Driver: C:\WINDOWS\system32\drivers\usbuhci.sys, 5.01.2600.2993 (English), 11/20/2006 09:50:12, 20608 bytes
   Driver: C:\WINDOWS\system32\drivers\usbport.sys, 5.01.2600.2993 (English), 11/20/2006 09:50:12, 143488 bytes
   Driver: C:\WINDOWS\system32\usbui.dll, 5.01.2600.2180 (English), 8/4/2004 01:56:48, 74240 bytes
   Driver: C:\WINDOWS\system32\drivers\usbhub.sys, 5.01.2600.2987 (English), 11/20/2006 09:50:11, 59264 bytes
     Name: Intel(R) 82801EB USB2 Enhanced Host Controller - 24DD
Device ID: PCI\VEN_8086&DEV_24DD&SUBSYS_24D01849&REV_02\3&267A616A&0&EF
   Driver: C:\WINDOWS\system32\drivers\usbehci.sys, 5.01.2600.2993 (English), 11/20/2006 09:50:11, 30208 bytes
   Driver: C:\WINDOWS\system32\hccoin.dll, 5.01.2600.2180 (English), 8/4/2004 00:56:44, 7168 bytes
     Name: Intel(R) 82801EB Ultra ATA Storage Controllers - 24DB
Device ID: PCI\VEN_8086&DEV_24DB&SUBSYS_24D01849&REV_02\3&267A616A&0&F9
   Driver: C:\WINDOWS\system32\DRIVERS\intelide.sys, 5.01.2600.2180 (English), 8/3/2004 23:59:42, 5504 bytes
   Driver: C:\WINDOWS\system32\DRIVERS\pciidex.sys, 5.01.2600.2180 (English), 8/3/2004 22:59:42, 25088 bytes
   Driver: C:\WINDOWS\system32\DRIVERS\atapi.sys, 5.01.2600.2180 (English), 8/3/2004 22:59:44, 95360 bytes
     Name: Intel(R) 82801EB USB Universal Host Controller - 24D7
Device ID: PCI\VEN_8086&DEV_24D7&SUBSYS_24D01849&REV_02\3&267A616A&0&EA
     Name: Intel(R) 82801EB USB Universal Host Controller - 24D4
Device ID: PCI\VEN_8086&DEV_24D4&SUBSYS_24D01849&REV_02\3&267A616A&0&E9
     Name: Intel(R) 82801EB SMBus Controller - 24D3
Device ID: PCI\VEN_8086&DEV_24D3&SUBSYS_24D01849&REV_02\3&267A616A&0&FB
   Driver: n/a
     Name: Intel(R) 82801EB USB Universal Host Controller - 24D2
Device ID: PCI\VEN_8086&DEV_24D2&SUBSYS_24D01849&REV_02\3&267A616A&0&E8
     Name: Intel(R) 82801EB Ultra ATA Storage Controllers - 24D1
Device ID: PCI\VEN_8086&DEV_24D1&SUBSYS_24D11849&REV_02\3&267A616A&0&FA
     Name: Intel(R) 82801EB LPC Interface Controller - 24D0
Device ID: PCI\VEN_8086&DEV_24D0&SUBSYS_00000000&REV_02\3&267A616A&0&F8
   Driver: C:\WINDOWS\system32\DRIVERS\isapnp.sys, 5.01.2600.0000 (English), 8/23/2001 13:00:00, 35840 bytes
     Name: Intel(R) 82801 PCI Bridge - 244E
Device ID: PCI\VEN_8086&DEV_244E&SUBSYS_00000000&REV_C2\3&267A616A&0&F0
   Driver: C:\WINDOWS\system32\DRIVERS\pci.sys, 5.01.2600.2180 (English), 8/3/2004 23:07:48, 68224 bytes
     Name: OHCI Compliant IEEE 1394 Host Controller
Device ID: PCI\VEN_1102&DEV_4001&SUBSYS_00101102&REV_04\4&2E98101C&0&12F0
   Driver: C:\WINDOWS\system32\DRIVERS\ohci1394.sys, 5.01.2600.2738 (English), 11/20/2006 09:49:42, 61312 bytes
   Driver: C:\WINDOWS\system32\DRIVERS\1394bus.sys, 5.01.2600.2180 (English), 8/3/2004 23:10:08, 53248 bytes
   Driver: C:\WINDOWS\system32\DRIVERS\nic1394.sys, 5.01.2600.2180 (English), 11/20/2006 09:57:37, 61824 bytes
   Driver: C:\WINDOWS\system32\DRIVERS\arp1394.sys, 5.01.2600.2180 (English), 11/20/2006 09:57:37, 60800 bytes
   Driver: C:\WINDOWS\system32\DRIVERS\enum1394.sys, 5.01.2600.0000 (English), 8/17/2001 14:46:40, 6400 bytes
     Name: Creative SB Audigy 2 (WDM)
Device ID: PCI\VEN_1102&DEV_0004&SUBSYS_10031102&REV_04\4&2E98101C&0&10F0
   Driver: C:\WINDOWS\system32\ksuser.dll, 5.03.2600.2180 (English), 8/4/2004 00:56:44, 4096 bytes
   Driver: C:\WINDOWS\system32\ksproxy.ax, 5.03.2600.2180 (English), 8/4/2004 00:56:58, 130048 bytes
   Driver: C:\WINDOWS\system32\drivers\ks.sys, 5.03.2600.2180 (English), 8/3/2004 23:15:22, 140928 bytes
   Driver: C:\WINDOWS\system32\drivers\drmk.sys, 5.01.2600.2180 (English), 8/3/2004 23:08:00, 60288 bytes
   Driver: C:\WINDOWS\system32\drivers\portcls.sys, 5.01.2600.2950 (English), 7/12/2006 14:50:00, 146048 bytes
   Driver: C:\WINDOWS\system32\drivers\stream.sys, 5.03.2600.2790 (English), 11/5/2005 01:55:10, 48768 bytes
   Driver: C:\WINDOWS\system32\wdmaud.drv, 5.01.2600.2180 (English), 8/4/2004 00:56:58, 23552 bytes
   Driver: C:\WINDOWS\system32\drivers\ctac32k.sys, 5.12.0001.1196 (English), 8/11/2006 14:45:14, 502272 bytes
   Driver: C:\WINDOWS\system32\drivers\ctaud2k.sys, 5.12.0001.1196 (English), 8/11/2006 14:45:38, 499584 bytes
   Driver: C:\WINDOWS\system32\drivers\ctoss2k.sys, 5.12.0001.1196 (English), 8/11/2006 14:45:24, 116224 bytes
   Driver: C:\WINDOWS\system32\drivers\ctprxy2k.sys, 5.12.0001.1196 (English), 8/11/2006 14:45:40, 7168 bytes
   Driver: C:\WINDOWS\system32\drivers\ctsfm2k.sys, 5.12.0001.1196 (English), 8/11/2006 14:45:18, 143872 bytes
   Driver: C:\WINDOWS\system32\drivers\emupia2k.sys, 5.12.0001.1196 (English), 8/11/2006 14:45:18, 78336 bytes
   Driver: C:\WINDOWS\system32\drivers\ha10kx2k.sys, 5.12.0001.1196 (English), 8/11/2006 14:45:26, 766976 bytes
   Driver: C:\WINDOWS\system32\drivers\haP16v2k.sys, 5.12.0001.1196 (English), 8/11/2006 14:45:26, 154112 bytes
   Driver: C:\WINDOWS\system32\drivers\haP17v2k.sys, 5.12.0001.1196 (English), 8/11/2006 14:45:28, 180224 bytes
   Driver: C:\WINDOWS\system32\drivers\ha20x2k.sys, 5.12.0001.1196 (English), 8/11/2006 14:45:32, 1110016 bytes
   Driver: C:\WINDOWS\system32\drivers\pfmodnt.sys, 3.00.0000.0012 (English), 8/11/2006 14:56:36, 8192 bytes
   Driver: C:\WINDOWS\system32\ctdlang.dat, 8/11/2006 14:49:24, 323640 bytes
   Driver: C:\WINDOWS\system32\ctdnlstr.dat, 8/11/2006 14:49:24, 44567 bytes
   Driver: C:\WINDOWS\system32\ctstatic.dat, 8/11/2006 14:43:04, 313207 bytes
   Driver: C:\WINDOWS\system32\ctdaught.dat, 8/11/2006 14:43:04, 53932 bytes
   Driver: C:\WINDOWS\system32\a3d.dll, 80.00.0000.0003 (English), 8/11/2006 14:56:28, 33792 bytes
   Driver: C:\WINDOWS\system32\commonfx.dll, 5.12.0001.1196 (English), 8/11/2006 14:48:08, 87552 bytes
   Driver: C:\WINDOWS\system32\ctaudfx.dll, 5.12.0001.1196 (English), 8/11/2006 14:48:12, 536576 bytes
   Driver: C:\WINDOWS\system32\ctsblfx.dll, 5.12.0001.1196 (English), 8/11/2006 14:48:32, 548352 bytes
   Driver: C:\WINDOWS\system32\cteapsfx.dll, 5.12.0001.1196 (English), 8/11/2006 14:48:28, 160768 bytes
   Driver: C:\WINDOWS\system32\CTEXFIFX.dll, 5.12.0001.1196 (English), 8/11/2006 14:48:42, 1170432 bytes
   Driver: C:\WINDOWS\system32\CTHWIUT.DLL, 5.12.0001.1196 (English), 8/11/2006 14:48:52, 61952 bytes
   Driver: C:\WINDOWS\system32\CT20XUT.DLL, 5.12.0001.1196 (English), 8/11/2006 14:48:50, 158720 bytes
   Driver: C:\WINDOWS\system32\ctemupia.dll, 5.12.0001.1196 (English), 8/11/2006 14:48:52, 108032 bytes
   Driver: C:\WINDOWS\system32\piaproxy.dll, 5.12.0001.1196 (English), 8/11/2006 14:45:16, 73728 bytes
   Driver: C:\WINDOWS\system32\ctdproxy.dll, 5.12.0001.1196 (English), 8/11/2006 14:45:34, 71680 bytes
   Driver: C:\WINDOWS\system32\sfman32.dll, 5.12.0001.0130 (English), 8/11/2006 14:45:20, 21504 bytes
   Driver: C:\WINDOWS\system32\ctbas2w.dat, 8/11/2006 14:45:08, 140643 bytes
   Driver: C:\WINDOWS\system32\ctsbas2w.dat, 8/11/2006 14:43:26, 265042 bytes
   Driver: C:\WINDOWS\system32\SBAudigy.ico, 8/17/2001 12:42:28, 7406 bytes
   Driver: C:\WINDOWS\system32\Audigy.bmp, 11/13/2001 09:48:20, 1912 bytes
   Driver: C:\WINDOWS\system32\ctcoinst.dll, 3.00.0002.0036 (English), 8/11/2006 14:57:04, 81920 bytes
   Driver: C:\WINDOWS\system32\ctdvinst.dll, 0.04.0000.0036 (English), 8/11/2006 14:57:06, 146432 bytes
   Driver: C:\WINDOWS\system32\drivers\ctdvda2k.sys, 5.13.0001.0467 (English), 11/10/2005 17:06:04, 340704 bytes
     Name: Realtek RTL8139 Family PCI Fast Ethernet NIC
Device ID: PCI\VEN_10EC&DEV_8139&SUBSYS_81391849&REV_10\4&2E98101C&0&28F0
   Driver: C:\WINDOWS\system32\DRIVERS\RTL8139.sys, 5.398.0613.2003 (English), 8/3/2004 23:31:34, 20992 bytes
     Name: Radeon X1950 Pro Secondary
Device ID: PCI\VEN_1002&DEV_72A0&SUBSYS_E191174B&REV_9A\4&38B71F77&0&0108
   Driver: C:\WINDOWS\system32\DRIVERS\ati2mtag.sys, 6.14.0010.6715 (English), 8/17/2007 04:09:20, 2371584 bytes
   Driver: C:\WINDOWS\system32\DRIVERS\ati2erec.dll, 1.00.0000.0012 (English), 8/17/2007 03:20:48, 49152 bytes
   Driver: C:\WINDOWS\system32\DRIVERS\ativvpxx.vp, 8/17/2007 08:02:32, 45296 bytes
   Driver: C:\WINDOWS\system32\DRIVERS\ativckxx.vp, 5/30/2007 17:43:04, 2096 bytes
   Driver: C:\WINDOWS\system32\DRIVERS\ativcaxx.vp, 4/18/2007 13:19:24, 929 bytes
   Driver: C:\WINDOWS\system32\DRIVERS\ativcaxx.cpa, 4/18/2007 13:19:24, 1311202 bytes
   Driver: C:\WINDOWS\system32\DRIVERS\ativdkxx.vp, 4/18/2007 13:19:50, 2096 bytes
   Driver: C:\WINDOWS\system32\ati2dvag.dll, 6.14.0010.6715 (English), 8/17/2007 04:09:40, 269312 bytes
   Driver: C:\WINDOWS\system32\ati2cqag.dll, 6.14.0010.0348 (English), 8/17/2007 03:18:44, 450560 bytes
   Driver: C:\WINDOWS\system32\Ati2mdxx.exe, 6.14.0010.2495 (English), 8/17/2007 04:01:26, 26112 bytes
   Driver: C:\WINDOWS\system32\ati3duag.dll, 6.14.0010.0523 (English), 8/17/2007 03:50:44, 3091392 bytes
   Driver: C:\WINDOWS\system32\ativvaxx.dll, 6.14.0010.0163 (English), 8/17/2007 03:39:54, 1550208 bytes
   Driver: C:\WINDOWS\system32\atiicdxx.dat, 6/12/2007 18:30:02, 151367 bytes
   Driver: C:\WINDOWS\system32\ativvaxx.dat, 8/17/2007 03:39:36, 3107788 bytes
   Driver: C:\WINDOWS\system32\ativva5x.dat, 8/17/2007 03:39:36, 3107788 bytes
   Driver: C:\WINDOWS\system32\ativva6x.dat, 8/17/2007 03:39:36, 972072 bytes
   Driver: C:\WINDOWS\system32\ATIDDC.DLL, 6.14.0010.0008 (English), 8/17/2007 03:58:50, 53248 bytes
   Driver: C:\WINDOWS\system32\atitvo32.dll, 6.14.0010.4200 (English), 8/17/2007 03:24:42, 17408 bytes
   Driver: C:\WINDOWS\system32\ativcoxx.dll, 6.13.0010.0005 (English), 11/9/2001 16:01:04, 24064 bytes
   Driver: C:\WINDOWS\system32\ati2evxx.exe, 6.14.0010.4174 (English), 8/17/2007 03:59:40, 483328 bytes
   Driver: C:\WINDOWS\system32\ati2evxx.dll, 6.14.0010.4163 (English), 8/17/2007 04:01:00, 118784 bytes
   Driver: C:\WINDOWS\system32\atipdlxx.dll, 6.14.0010.2522 (English), 8/17/2007 04:01:44, 143360 bytes
   Driver: C:\WINDOWS\system32\Oemdspif.dll, 6.14.0001.0016 (English), 3/23/2007 21:23:22, 77824 bytes
   Driver: C:\WINDOWS\system32\ati2edxx.dll, 6.14.0010.2512 (English), 8/17/2007 04:01:16, 43520 bytes
   Driver: C:\WINDOWS\system32\atikvmag.dll, 6.14.0010.0062 (English), 8/17/2007 03:26:16, 266240 bytes
   Driver: C:\WINDOWS\system32\atifglpf.xml, 4/12/2007 02:33:46, 7069 bytes
   Driver: C:\WINDOWS\system32\ATIDEMGX.dll, 2.00.2784.39922 (English), 8/17/2007 04:10:44, 344064 bytes
   Driver: C:\WINDOWS\system32\atioglxx.dll, 6.14.0010.6747 (English), 8/17/2007 03:40:36, 5435392 bytes
   Driver: C:\WINDOWS\system32\atiok3x2.dll, 6.14.0010.0001 (English), 8/17/2007 03:58:38, 176128 bytes
   Driver: C:\WINDOWS\system32\atioglx2.dll, 6.14.0010.6747 (English), 8/17/2007 04:30:30, 8237056 bytes
   Driver: C:\WINDOWS\system32\atiiiexx.dll, 6.14.0010.4005 (English), 8/17/2007 04:08:46, 307200 bytes
   Driver: C:\WINDOWS\atiogl.xml, 5/3/2007 18:52:52, 11557 bytes
Device ID: PCI\VEN_1002&DEV_7280&SUBSYS_E190174B&REV_9A\4&38B71F77&0&0008
DirectX Components
   ddraw.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:44 266240 bytes
 ddrawex.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:44 27136 bytes
   dxapi.sys: 5.01.2600.0000 English Final Retail 8/23/2001 13:00:00 10496 bytes
    d3d8.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:42 1179648 bytes
 d3d8thk.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:42 8192 bytes
    d3d9.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:42 1689088 bytes
   d3dim.dll: 5.01.2600.0000 English Final Retail 8/23/2001 13:00:00 436224 bytes
d3dim700.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:42 825344 bytes
 d3dramp.dll: 5.01.2600.0000 English Final Retail 8/23/2001 13:00:00 590336 bytes
   d3drm.dll: 5.01.2600.0000 English Final Retail 8/23/2001 13:00:00 350208 bytes
  d3dxof.dll: 5.01.2600.0000 English Final Retail 8/23/2001 13:00:00 47616 bytes
d3dpmesh.dll: 5.01.2600.0000 English Final Retail 8/23/2001 13:00:00 34816 bytes
   dplay.dll: 5.00.2134.0001 English Final Retail 8/23/2001 13:00:00 33040 bytes
  dplayx.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:44 229888 bytes
dpmodemx.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:44 23552 bytes
 dpwsock.dll: 5.00.2134.0001 English Final Retail 8/23/2001 13:00:00 42768 bytes
dpwsockx.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:44 57344 bytes
dplaysvr.exe: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:50 30208 bytes
  dpnsvr.exe: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:50 18432 bytes
   dpnet.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:44 375296 bytes
dpnlobby.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:04 3584 bytes
 dpnaddr.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:04 3584 bytes
 dpvoice.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:44 212480 bytes
dpvsetup.exe: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:50 83456 bytes
  dpvvox.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:44 116736 bytes
  dpvacm.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:44 21504 bytes
dpnhpast.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:44 35328 bytes
dpnhupnp.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:44 60928 bytes
dpserial.dll: 5.00.2134.0001 English Final Retail 8/23/2001 13:00:00 53520 bytes
  dinput.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:44 159232 bytes
 dinput8.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:44 181760 bytes
   dimap.dll: 5.01.2600.0000 English Final Retail 8/23/2001 13:00:00 44032 bytes
diactfrm.dll: 5.01.2600.0000 English Final Retail 8/23/2001 13:00:00 394240 bytes
     joy.cpl: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:58 68608 bytes
   gcdef.dll: 5.01.2600.0000 English Final Retail 8/23/2001 13:00:00 76800 bytes
     pid.dll: 5.03.2600.2180 English Final Retail 11/20/2006 09:57:37 35328 bytes
  dsound.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:44 367616 bytes
dsound3d.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:44 1294336 bytes
  dswave.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:44 19456 bytes
   dsdmo.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:44 181760 bytes
dsdmoprp.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:44 71680 bytes
  dmusic.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:44 104448 bytes
  dmband.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:44 28672 bytes
dmcompos.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:44 61440 bytes
   dmime.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:44 181248 bytes
dmloader.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:44 35840 bytes
 dmstyle.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:44 105984 bytes
 dmsynth.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:44 103424 bytes
dmscript.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:44 82432 bytes
Microsoft.DirectX.Direct3D.dll: 9.05.0132.0000 English Final Retail 8/20/2007 15:07:37 473600 bytes
Microsoft.DirectX.Direct3DX.dll: 5.04.0000.3900 English Final Retail 8/20/2007 15:07:29 2676224 bytes
Microsoft.DirectX.Direct3DX.dll: 9.04.0091.0000 English Final Retail 8/20/2007 15:07:31 2846720 bytes
Microsoft.DirectX.Direct3DX.dll: 9.05.0132.0000 English Final Retail 8/20/2007 15:07:32 563712 bytes
Microsoft.DirectX.Direct3DX.dll: 9.06.0168.0000 English Final Retail 8/20/2007 15:07:32 567296 bytes
Microsoft.DirectX.Direct3DX.dll: 9.07.0239.0000 English Final Retail 8/20/2007 15:07:32 576000 bytes
Microsoft.DirectX.Direct3DX.dll: 9.08.0299.0000 English Final Retail 8/20/2007 15:07:33 577024 bytes
Microsoft.DirectX.Direct3DX.dll: 9.09.0376.0000 English Final Retail 8/20/2007 15:07:34 577536 bytes
Microsoft.DirectX.Direct3DX.dll: 9.10.0455.0000 English Final Retail 8/20/2007 15:07:34 577536 bytes
Microsoft.DirectX.Direct3DX.dll: 9.11.0519.0000 English Final Retail 8/20/2007 15:07:34 578560 bytes
Microsoft.DirectX.Direct3DX.dll: 9.12.0589.0000 English Final Retail 8/20/2007 15:07:37 578560 bytes
Microsoft.DirectX.DirectDraw.dll: 5.04.0000.2904 English Final Retail 8/20/2007 15:07:37 145920 bytes
Microsoft.DirectX.DirectInput.dll: 5.04.0000.2904 English Final Retail 8/20/2007 15:07:38 159232 bytes
Microsoft.DirectX.DirectPlay.dll: 5.04.0000.2904 English Final Retail 8/20/2007 15:07:38 364544 bytes
Microsoft.DirectX.DirectSound.dll: 5.04.0000.2904 English Final Retail 8/20/2007 15:07:39 178176 bytes
Microsoft.DirectX.AudioVideoPlayback.dll: 5.04.0000.2904 English Final Retail 8/20/2007 15:07:36 53248 bytes
Microsoft.DirectX.Diagnostics.dll: 5.04.0000.2904 English Final Retail 8/20/2007 15:07:36 12800 bytes
Microsoft.DirectX.dll: 5.04.0000.2904 English Final Retail 8/20/2007 15:07:35 223232 bytes
   dx7vb.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:44 619008 bytes
   dx8vb.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:44 1227264 bytes
 dxdiagn.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:44 2113536 bytes
   mfc40.dll: 4.01.0000.6140 English Final Retail 8/23/2001 13:00:00 924432 bytes
   mfc42.dll: 6.02.4131.0000 English Final Retail 8/4/2004 00:56:44 1028096 bytes
 wsock32.dll: 5.01.2600.2180 English Final Retail 8/4/2004 00:56:48 22528 bytes
amstream.dll: 6.05.2600.2180 English Final Retail 8/4/2004 00:56:42 70656 bytes
 devenum.dll: 6.05.2600.2180 English Final Retail 8/4/2004 00:56:44 59904 bytes
  dxmasf.dll: 6.04.0009.1133 English Final Retail 8/22/2006 04:05:26 498742 bytes
mciqtz32.dll: 6.05.2600.2180 English Final Retail 8/4/2004 00:56:44 35328 bytes
 mpg2splt.ax: 6.05.2600.2180 English Final Retail 8/4/2004 00:56:58 148992 bytes
   msdmo.dll: 6.05.2600.2180 English Final Retail 8/4/2004 00:56:44 14336 bytes
  encapi.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:44 20480 bytes
    qasf.dll: 11.00.5721.5145 English Final Retail 10/18/2006 21:47:18 211456 bytes
    qcap.dll: 6.05.2600.2180 English Final Retail 8/4/2004 00:56:46 192512 bytes
     qdv.dll: 6.05.2600.2180 English Final Retail 8/4/2004 00:56:46 279040 bytes
    qdvd.dll: 6.05.2600.2831 English Final Retail 11/20/2006 09:49:45 386048 bytes
   qedit.dll: 6.05.2600.2180 English Final Retail 8/4/2004 00:56:46 562176 bytes
qedwipes.dll: 6.05.2600.2180 English Final Retail 8/4/2004 00:56:26 733696 bytes
  quartz.dll: 6.05.2600.2905 English Final Retail 11/20/2006 09:49:47 1287680 bytes
 strmdll.dll: 4.01.0000.3936 English Final Retail 8/21/2006 09:52:08 246814 bytes
 iac25_32.ax: 2.00.0005.0053 English Final Retail 8/4/2004 00:56:58 199680 bytes
  ir41_32.ax: 4.51.0016.0003 English Final Retail 8/4/2004 00:56:58 848384 bytes
 ir41_qc.dll: 4.30.0062.0002 English Final Retail 8/4/2004 00:56:44 120320 bytes
ir41_qcx.dll: 4.30.0064.0001 English Final Retail 8/4/2004 00:56:44 338432 bytes
 ir50_32.dll: 5.2562.0015.0055 English Final Retail 8/4/2004 00:56:44 755200 bytes
 ir50_qc.dll: 5.00.0063.0048 English Final Retail 8/4/2004 00:56:44 200192 bytes
ir50_qcx.dll: 5.00.0064.0048 English Final Retail 8/4/2004 00:56:44 183808 bytes
   ivfsrc.ax: 5.10.0002.0051 English Final Retail 8/4/2004 00:56:58 154624 bytes
mswebdvd.dll: 6.05.2600.2180 English Final Retail 8/4/2004 00:56:46 204288 bytes
      ks.sys: 5.03.2600.2180 English Final Retail 8/3/2004 23:15:22 140928 bytes
  ksproxy.ax: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:58 130048 bytes
  ksuser.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:44 4096 bytes
  stream.sys: 5.03.2600.2790 English Final Retail 11/5/2005 01:55:10 48768 bytes
mspclock.sys: 5.03.2600.2180 English Final Retail 8/3/2004 22:58:40 5376 bytes
   mspqm.sys: 5.01.2600.2180 English Final Retail 8/3/2004 22:58:42 4992 bytes
 mskssrv.sys: 5.03.2600.2180 English Final Retail 8/3/2004 22:58:42 7552 bytes
  swenum.sys: 5.03.2600.2180 English Final Retail 11/20/2006 09:57:37 4352 bytes
   mstee.sys: 5.03.2600.2180 English Final Retail 8/3/2004 22:58:40 5504 bytes
 bdaplgin.ax: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:58 18432 bytes
  bdasup.sys: 5.03.2600.2180 English Final Retail 8/3/2004 23:10:14 11776 bytes
  msdvbnp.ax: 6.05.2600.2180 English Final Retail 8/4/2004 00:56:58 56832 bytes
psisdecd.dll: 6.05.2600.2640 English Final Retail 3/25/2005 22:42:50 363520 bytes
 psisrndr.ax: 6.05.2600.2180 English Final Retail 8/4/2004 00:56:58 33280 bytes
   ipsink.ax: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:58 16384 bytes
mpeg2data.ax: 6.05.2600.2180 English Final Retail 8/4/2004 00:56:58 118272 bytes
  ndisip.sys: 5.03.2600.2180 English Final Retail 8/3/2004 23:10:14 10880 bytes
     mpe.sys: 5.03.2600.2180 English Final Retail 8/3/2004 23:10:14 15360 bytes
streamip.sys: 5.03.2600.2180 English Final Retail 8/3/2004 23:10:14 15360 bytes
msvidctl.dll: 6.05.2600.2180 English Final Retail 8/4/2004 00:56:44 1428480 bytes
    slip.sys: 5.03.2600.2180 English Final Retail 8/3/2004 23:10:18 11136 bytes
nabtsfec.sys: 5.03.2600.2180 English Final Retail 8/3/2004 23:10:30 85376 bytes
ccdecode.sys: 5.03.2600.2180 English Final Retail 8/3/2004 23:10:18 17024 bytes
  vbisurf.ax: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:58 30720 bytes
   msyuv.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:46 17408 bytes
 kstvtune.ax: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:58 61952 bytes
   ksxbar.ax: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:58 43008 bytes
 kswdmcap.ax: 5.03.2600.2729 English Final Retail 7/30/2005 03:55:10 90624 bytes
vfwwdm32.dll: 5.01.2600.2180 English Final Retail 8/4/2004 00:56:48 53760 bytes
wstcodec.sys: 5.03.2600.2180 English Final Retail 8/3/2004 23:10:22 19328 bytes
wstdecod.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:48 50688 bytes
DirectShow Filters
WDM Streaming VBI Codecs:
NABTS/FEC VBI Codec,0x00200000,2,1,,5.03.2600.2180
CC Decoder,0x00200000,2,1,,5.03.2600.2180
WST Codec,0x00200000,1,1,,5.03.2600.2180
DirectShow Filters:
WMAudio Decoder DMO,0x00800800,1,1,,
WMAPro over S/PDIF DMO,0x00600800,1,1,,
WMA Voice Decoder DMO,0x00600800,1,1,,
WMVideo Advanced Decoder DMO,0x00800001,1,1,,
Mpeg4s Decoder DMO,0x00800001,1,1,,
WMV Screen decoder DMO,0x00800001,1,1,,
WMVideo Decoder DMO,0x00800001,1,1,,
Mpeg43 Decoder DMO,0x00800001,1,1,,
Mpeg4 Decoder DMO,0x00800001,1,1,,
WMT MuxDeMux Filter,0x00200000,0,0,wmm2filt.dll,2.01.4026.0000
VP6 Decompressor,0x00800000,1,1,vp6dec.ax,6.04.0002.0000
ATI Media Center Video Encoder,0x00600000,1,1,atimcenc.dll,9.14.0000.60829
ffdshow Video Decoder,0xff800001,2,1,ffdshow.ax,1.00.0003.1368
Creative LiveRecording Filter,0x00400000,0,1,LiveRec.ax,1.01.0012.0000
Full Screen Renderer,0x00200000,1,0,quartz.dll,6.05.2600.2905
ATI MPEG Audio Decoder,0x00200000,1,1,atidvcr.dll,9.14.0000.4873
CoreVorbis Audio Decoder,0x00800000,1,1,CoreVorbis.ax,1.01.0000.0079
CoreAVC Video Decoder,0x00600200,1,1,CoreAVCDecoder.ax,1.03.0000.0000
ffdshow raw video filter,0x00200000,2,1,ffdshow.ax,1.00.0003.1368
Nero Scene Detector 2,0x00200000,2,0,,
ffdshow Audio Decoder,0x3fffffff,1,1,ffdshow.ax,1.00.0003.1368
ATI Ticker,0x00200000,0,1,Ticker.ax,
Creative Wave Writer,0x00200000,1,0,WavWrite.ax,1.01.0009.0000
DV Muxer,0x00400000,0,0,qdv.dll,6.05.2600.2180
Mpeg Source,0x00200000,0,0,MpegSplitter.ax,1.00.0000.0004
Nero Digital Audio Decoder,0x00600000,1,1,,
Creative MLP Source Filter,0x00400000,0,1,MlpSrc.ax,1.01.0001.0000
DV Scenes,0x00200000,1,1,NVDV.dll,3.00.0002.0001
Color Space Converter,0x00400001,1,1,quartz.dll,6.05.2600.2905
ATI EZShare Server,0x00200000,1,0,atidvcr.dll,9.14.0000.4873
WM ASF Reader,0x00400000,0,0,qasf.dll,11.00.5721.5145
Creative NVF Filter,0x00400000,0,1,NvfSrc.ax,1.00.0006.0000
Screen Capture filter,0x00200000,0,1,wmpsrcwp.dll,11.00.5721.5145
AVI Splitter,0x00600000,1,1,quartz.dll,6.05.2600.2905
WMT AudioAnalyzer,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
VGA 16 Color Ditherer,0x00400000,1,1,quartz.dll,6.05.2600.2905
Indeo® video 5.10 Compression Filter,0x00200000,1,1,Ir50_32.dll,5.2562.0015.0055
Windows Media Audio Decoder,0x00800001,1,1,msadds32.ax,8.00.0000.4487
AC3 Parser Filter,0x00600000,1,1,mpg2splt.ax,6.05.2600.2180
CT Null Render Filter,0x00200000,1,0,NullRndr.ax,1.00.0001.0000
WMT Format Conversion,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
CT Time-Scaling filter,0x00100000,1,1,TimeScal.ax,2.00.0000.0001
StreamBufferSink,0x00200000,0,0,sbe.dll,6.05.2600.2180
WMT Black Frame Generator,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Nero Resize,0x00200000,1,1,,
MJPEG Decompressor,0x00600000,1,1,quartz.dll,6.05.2600.2905
Indeo® video 5.10 Decompression Filter,0x00640000,1,1,Ir50_32.dll,5.2562.0015.0055
WMT Screen Capture filter,0x00200000,0,1,wmm2filt.dll,2.01.4026.0000
Microsoft Screen Video Decompressor,0x00800000,1,1,msscds32.ax,8.00.0000.4487
MPEG-I Stream Splitter,0x00600000,1,2,quartz.dll,6.05.2600.2905
SAMI (CC) Parser,0x00400000,1,1,quartz.dll,6.05.2600.2905
ATI EZShare Client,0x00200000,0,1,atidvcr.dll,9.14.0000.4873
ATI Time Shift Splitter,0x00600000,1,2,atidvcr.dll,9.14.0000.4873
ATI Time Shift Reader,0x00600000,0,1,atidvcr.dll,9.14.0000.4873
ATI MPEG File Writer,0x00200000,1,0,atidvcr.dll,9.14.0000.4873
ATI MPEG Video Decoder,0x005fffff,1,2,atidvcr.dll,9.14.0000.4873
MPEG Layer-3 Decoder,0x00810000,1,1,l3codecx.ax,1.09.0000.0311
Nero Audio Stream Renderer,0x00200000,1,0,,
MPEG-2 Splitter,0x005fffff,1,0,mpg2splt.ax,6.05.2600.2180
MP4 Source,0x00600000,0,0,MP4Splitter.ax,1.00.0000.0002
ACELP.net Sipro Lab Audio Decoder,0x00800001,1,1,acelpdec.ax,1.04.0000.0000
Nero Digital AVC Audio Encoder,0x00200000,1,2,,
Nero Digital AVC File Writer,0x00200000,1,0,,
Nero Digital AVC Null Renderer,0x00200000,1,0,,
Nero Digital AVC Muxer,0x00200000,2,1,,
Nero Digital AVC Video Enc,0x00200000,1,2,,
ATI VCR Video Converter,0x00200000,1,1,atidvcr.dll,9.14.0000.4873
WMS Filter,0x00400000,0,1,CTWMSFLT.DLL,1.12.0001.0000
Nero QuickTime(tm) Video Decoder,0x00400000,1,1,,
FLV Splitter,0x00600000,1,1,FLVSplitter.ax,1.00.0000.0002
Internal Script Command Renderer,0x00800001,1,0,quartz.dll,6.05.2600.2905
MPEG Audio Decoder,0x03680001,1,1,quartz.dll,6.05.2600.2905
MMACE ProcAmp,0x00200000,0,2,MMACEFilters.dll,
WavPack Audio Decoder,0x00600000,1,1,WavPackDSDecoder.ax,1.01.0000.0482
File Source (Netshow URL),0x00400000,0,1,wmpasf.dll,11.00.5721.5145
Nero Digital AVC Subpicture Enc,0x00200000,1,0,,
Nero Format Converter,0x00200000,1,1,,
ATI Video Format Converter,0x00200000,1,1,atidvcr.dll,9.14.0000.4873
WMT Import Filter,0x00200000,0,1,wmm2filt.dll,2.01.4026.0000
DV Splitter,0x00600000,1,2,qdv.dll,6.05.2600.2180
Bitmap Generate,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Windows Media Video Decoder,0x00800000,1,1,wmvds32.ax,8.00.0000.4487
Video Mixing Renderer 9,0x00200000,1,0,quartz.dll,6.05.2600.2905
Windows Media Video Decoder,0x00800000,1,1,wmv8ds32.ax,8.00.0000.4000
Nero Photo Source,0x00200000,0,1,,
CDDA Reader,0x00600000,0,1,cddareader.ax,1.00.0000.0001
Haali Media Splitter,0x00800001,0,1,splitter.ax,1.07.0189.0011
WMT VIH2 Fix,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Nero Video Analyzer,0x00200000,2,0,,
Record Queue,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
ATI Media Center Audio Encoder,0x00600000,1,1,atimcenc.dll,9.14.0000.60829
Nero ES Video Reader,0x00600000,0,1,,
DV Source Filter,0x00400000,0,1,NVDV.dll,3.00.0002.0001
MP4 Splitter,0x00600000,1,1,MP4Splitter.ax,1.00.0000.0002
Nero Audio CD Filter,0x00200000,0,1,,
Creative MP3 Source Filter,0x00400000,0,1,Mp3Src.ax,1.00.0010.0000
ATI CC Multiplexer,0x00200000,1,1,atidvcr.dll,9.14.0000.4873
Windows Media Multiplexer,0x00600000,1,1,wmpasf.dll,11.00.5721.5145
ASX file Parser,0x00600000,1,1,wmpasf.dll,11.00.5721.5145
ASX v.2 file Parser,0x00600000,1,0,wmpasf.dll,11.00.5721.5145
NSC file Parser,0x00600000,1,1,wmpasf.dll,11.00.5721.5145
ATI MPEG Audio Encoder,0x00200000,1,1,atidvcr.dll,9.14.0000.4873
ATI VCR Stream Sink,0x00200000,0,0,atidvcr.dll,9.14.0000.4873
RadLight OptimFROG DirectShow Filter,0x00600000,0,1,RLOFRDec.ax,1.00.0000.0001
ACM Wrapper,0x00600000,1,1,quartz.dll,6.05.2600.2905
Windows Media source filter,0x00600000,0,2,wmpasf.dll,11.00.5721.5145
Video Renderer,0x00800001,1,0,quartz.dll,6.05.2600.2905
Frame Eater,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Nero DVD Navigator,0x00600000,0,4,,
MPEG-2 Video Stream Analyzer,0x00200000,0,0,sbe.dll,6.05.2600.2180
ATI Media Center Multiplexer,0x00400000,2,1,atimcenc.dll,9.14.0000.60829
Line 21 Decoder,0x00600000,1,1,qdvd.dll,6.05.2600.2831
Video Port Manager,0x00600000,2,1,quartz.dll,6.05.2600.2905
WST Decoder,0x00600000,1,1,wstdecod.dll,5.03.2600.2180
Video Renderer,0x00400000,1,0,quartz.dll,6.05.2600.2905
ATI MPEG Video Encoder,0x00200000,1,1,atidvcr.dll,9.14.0000.4873
Haali Video Renderer,0x00200000,1,0,dxr.dll,
Nero Audio Sample Renderer,0x00200000,1,0,,
Nero Vcd Navigator,0x00600000,0,2,,
DivX Decoder Filter,0xff800000,1,1,divxdec.ax,6.06.0001.0004
Creative AC3 Source Filter,0x00400000,0,1,AC3Src.ax,1.01.0000.0000
Nero Audio Processor,0x00200000,1,1,,
ATI MPEG Multiplexer,0x00200000,2,1,atidvcr.dll,9.14.0000.4873
CT SmartVolumeManagement filter,0x00100000,1,1,DSCompr.ax,1.00.0000.0001
ATI Audio Delay Filter,0x00200000,1,1,atidvcr.dll,9.14.0000.4873
WM ASF Writer,0x00400000,0,0,qasf.dll,11.00.5721.5145
FLV Video Decoder,0x00600000,1,1,FLVSplitter.ax,1.00.0000.0002
WMT Sample Information Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Nero Mpeg2 Encoder,0x00200000,2,1,,
VBI Surface Allocator,0x00600000,1,1,vbisurf.ax,5.03.2600.2180
Creative MP3 Writer,0x00200000,1,0,MP3Write.ax,1.01.0008.0000
Microsoft MPEG-4 Video Decompressor,0x00800000,1,1,mpg4ds32.ax,8.00.0000.4487
Nero Video Stream Renderer,0x00200000,1,0,,
MMACE SoftEmu,0x00200000,0,2,MMACEFilters.dll,
File writer,0x00200000,1,0,qcap.dll,6.05.2600.2180
RadLight MPC DirectShow Filter,0x00600000,0,1,RLMPCDec.ax,1.00.0000.0004
CyberLink Video/SP Decoder (PDVD7),0x00602000,2,3,CLVSD.ax,6.00.0000.3402
ATI Video Scaler Filter,0x00200000,1,1,atidvcr.dll,9.14.0000.4873
Nero PS Muxer,0x00200000,1,1,,
Haali Simple Media Splitter,0x00200000,0,1,splitter.ax,1.07.0189.0011
WMT Log Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
WMT Virtual Renderer,0x00200000,1,0,wmm2filt.dll,2.01.4026.0000
DirectVobSub,0x00200000,2,1,vsfilter.dll,1.00.0001.0004
DirectVobSub (auto-loading version),0x00800002,2,1,vsfilter.dll,1.00.0001.0004
DVD Navigator,0x00200000,0,2,qdvd.dll,6.05.2600.2831
MMACE DeInterlace,0x00200000,0,2,MMACEFilters.dll,
Overlay Mixer2,0x00400000,1,1,qdvd.dll,6.05.2600.2831
Haali Matroska Muxer,0x00200000,1,0,splitter.ax,1.07.0189.0011
Nero Splitter,0x00600000,1,3,,
AC3Filter,0x40000000,1,1,ac3filter.ax,1.03.0001.0000
AVI Draw,0x00600064,9,1,quartz.dll,6.05.2600.2905
.RAM file Parser,0x00600000,1,0,wmpasf.dll,11.00.5721.5145
ATI CC Splitter Filter,0x00200000,1,1,atidvcr.dll,9.14.0000.4873
Nero File Source / Splitter,0x00600000,0,3,,
DC-Bass Source,0x00400000,0,1,DCBassSource.ax,1.01.0000.0000
WMT DirectX Transform Wrapper,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
G.711 Codec,0x00200000,1,1,g711codc.ax,5.01.2600.0000
MPEG-2 Demultiplexer,0x00600000,1,1,mpg2splt.ax,6.05.2600.2180
DV Video Decoder,0x00800000,1,1,qdv.dll,6.05.2600.2180
Creative MP3 Source Filter,0x00400000,0,1,CTMP3SFT.DLL,1.00.0010.0000
Indeo® audio software,0x00500000,1,1,iac25_32.ax,2.00.0005.0053
Windows Media Update Filter,0x00400000,1,0,wmpasf.dll,11.00.5721.5145
ffdshow Audio Processor,0x00200000,1,1,ffdshow.ax,1.00.0003.1368
Noise Reduction,0x00100000,1,1,NoisRedu.ax,2.00.0000.0001
ASF DIB Handler,0x00600000,1,1,wmpasf.dll,11.00.5721.5145
ASF ACM Handler,0x00600000,1,1,wmpasf.dll,11.00.5721.5145
ASF ICM Handler,0x00600000,1,1,wmpasf.dll,11.00.5721.5145
ASF URL Handler,0x00600000,1,1,wmpasf.dll,11.00.5721.5145
ASF JPEG Handler,0x00600000,1,1,wmpasf.dll,11.00.5721.5145
ASF DJPEG Handler,0x00600000,1,1,wmpasf.dll,11.00.5721.5145
ASF embedded stuff Handler,0x00600000,1,1,wmpasf.dll,11.00.5721.5145
9x8Resize,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
ATI Noise Reduction Filter,0x00200000,1,1,atidvcr.dll,9.14.0000.4873
WIA Stream Snapshot Filter,0x00200000,1,1,wiasf.ax,1.00.0000.0000
Nero Video Processor,0x00200000,1,1,,
Nero Video Decoder,0x00600000,2,2,,
Allocator Fix,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
SampleGrabber,0x00200000,1,1,qedit.dll,6.05.2600.2180
Null Renderer,0x00200000,1,0,qedit.dll,6.05.2600.2180
VP7 Decompressor,0x00800000,1,1,vp7dec.ax,7.00.0010.0000
Creative WMA Writer,0x00200000,1,0,WMAWrite.ax,1.01.0009.0000
WMT Virtual Source,0x00200000,0,1,wmm2filt.dll,2.01.4026.0000
MPEG-2 Sections and Tables,0x005fffff,1,0,Mpeg2Data.ax,6.05.2600.2180
IVF source filter,0x00600000,0,1,Ivfsrc.ax,5.10.0002.0051
WMT Interlacer,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Nero Audio CD Navigator,0x00200000,0,1,,
FLV Source,0x00600000,0,0,FLVSplitter.ax,1.00.0000.0002
StreamBufferSource,0x00200000,0,0,sbe.dll,6.05.2600.2180
ATI Audio Pitch Correction Filter,0x00200000,1,1,atidvcr.dll,9.14.0000.4873
Smart Tee,0x00200000,1,2,qcap.dll,6.05.2600.2180
Creative WMA Source Filter,0x00400000,0,1,WmaSrc.ax,1.00.0007.0000
Overlay Mixer,0x00200000,0,0,qdvd.dll,6.05.2600.2831
Nero Scene Detector,0x00200000,1,0,,
RealPlayer Audio Filter,0x00200000,1,1,rdsf3260.dll,6.00.0012.1755
AVI Decompressor,0x00600000,1,1,quartz.dll,6.05.2600.2905
Uncompressed Domain Shot Detection Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
AVI/WAV File Source,0x00400000,0,2,quartz.dll,6.05.2600.2905
CDXA Reader,0x00600000,0,1,cdxareader.ax,1.00.0000.0001
MPEG4 Video Splitter,0x00600000,1,1,MP4Splitter.ax,1.00.0000.0002
QuickTime Movie Parser,0x00600000,1,1,quartz.dll,6.05.2600.2905
Wave Parser,0x00400000,1,1,quartz.dll,6.05.2600.2905
MIDI Parser,0x00400000,1,1,quartz.dll,6.05.2600.2905
Multi-file Parser,0x00400000,1,1,quartz.dll,6.05.2600.2905
File stream renderer,0x00400000,1,1,quartz.dll,6.05.2600.2905
XML Playlist,0x00400000,1,0,wmpasf.dll,11.00.5721.5145
Nero File Source,0x00200000,0,1,,
Nero QuickTime(tm) Audio Decoder,0x00400000,1,1,,
WavPack Audio Splitter,0x00600000,1,1,WavPackDSSplitter.ax,1.01.0000.0319
Nero File Source (Async.),0x00400000,0,1,,
NVF Filter,0x00400000,0,1,CTNVFFLT.DLL,1.00.0000.0000
Mpeg Splitter,0x00600001,1,1,MpegSplitter.ax,1.00.0000.0004
Nero DVD Decoder,0x00600000,2,2,,
ATI Video Rotation Filter,0x00200000,1,1,atidvcr.dll,9.14.0000.4873
Nero Digital Parser,0x00600000,0,3,,
AVI Mux,0x00200000,1,0,qcap.dll,6.05.2600.2180
MPEG4 Video Source,0x00600000,0,0,MP4Splitter.ax,1.00.0000.0002
Line 21 Decoder 2,0x00600002,1,1,quartz.dll,6.05.2600.2905
File Source (Async.),0x00400000,0,1,quartz.dll,6.05.2600.2905
File Source (URL),0x00400000,0,1,quartz.dll,6.05.2600.2905
WMT DV Extract,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Creative CDDA Source Filter,0x00400000,0,1,CDDA.ax,1.01.0007.0000
Nero Frame Capture,0x00200000,1,1,,
WMT Switch Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
WMT Volume,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Nero Video Sample Renderer,0x00200000,1,0,,
Haali Video Sink,0x00200000,1,0,splitter.ax,1.07.0189.0011
ATI VCR Stream Source,0x00600000,0,0,atidvcr.dll,9.14.0000.4873
Stretch Video,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
AC3File,0x00600000,0,1,ac3file.ax,
Infinite Pin Tee Filter,0x00200000,1,1,qcap.dll,6.05.2600.2180
Nero DV Splitter,0x00200000,1,2,,
BDA MPEG2 Transport Information Filter,0x00200000,1,0,PsisRndr.ax,6.05.2600.2180
QT Decompressor,0x00600000,1,1,quartz.dll,6.05.2600.2905
ATI FM-On-Demand Filter,0x00200000,1,1,atidvcr.dll,9.14.0000.4873
MPEG Video Decoder,0x40000001,1,1,quartz.dll,6.05.2600.2905
Indeo® video 4.4 Decompression Filter,0x00640000,1,1,Ir41_32.ax,4.51.0016.0003
Indeo® video 4.4 Compression Filter,0x00200000,1,1,Ir41_32.ax,4.51.0016.0003
WDM Streaming Tee/Splitter Devices:
Tee/Sink-to-Sink Converter,0x00200000,1,1,,5.03.2600.2180
WDM Streaming Data Transforms:
Microsoft Kernel Acoustic Echo Canceller,0x00000000,0,0,,
Microsoft Kernel GS Wavetable Synthesizer,0x00200000,1,1,,5.03.2600.2180
Microsoft Kernel DLS Synthesizer,0x00200000,1,1,,5.03.2600.2180
Microsoft Kernel DRM Audio Descrambler,0x00200000,1,1,,5.03.2600.2180
Video Compressors:
WMVideo Encoder DMO,0x00600800,1,1,,
WMVideo8 Encoder DMO,0x00600800,1,1,,
MSScreen encoder DMO,0x00600800,1,1,,
WMVideo9 Encoder DMO,0x00600800,1,1,,
MSScreen 9 encoder DMO,0x00600800,1,1,,
DV Video Encoder,0x00200000,0,0,qdv.dll,6.05.2600.2180
ffdshow video encoder,0x00100000,1,1,ffdshow.ax,1.00.0003.1368
Indeo® video 5.10 Compression Filter,0x00100000,1,1,Ir50_32.dll,5.2562.0015.0055
MJPEG Compressor,0x00200000,0,0,quartz.dll,6.05.2600.2905
Cinepak Codec by Radius,0x00200000,1,1,qcap.dll,6.05.2600.2180
DivX® 6.6.1 Codec (2 Logical CPUs),0x00200000,1,1,qcap.dll,6.05.2600.2180
ffdshow Video Codec,0x00200000,1,1,qcap.dll,6.05.2600.2180
Huffyuv v2.1.1 - CCESP Patch v0.2.5,0x00200000,1,1,qcap.dll,6.05.2600.2180
Intel I.263 Video Driver 2.55.012,0x00200000,1,1,qcap.dll,6.05.2600.2180
Helix I420 YUV Codec,0x00200000,1,1,qcap.dll,6.05.2600.2180
Intel Indeo(R) Video R3.2,0x00200000,1,1,qcap.dll,6.05.2600.2180
Intel Indeo® Video 4.5,0x00200000,1,1,qcap.dll,6.05.2600.2180
Indeo® video 5.10,0x00200000,1,1,qcap.dll,6.05.2600.2180
Intel IYUV codec,0x00200000,1,1,qcap.dll,6.05.2600.2180
Microsoft H.261 Video Codec,0x00200000,1,1,qcap.dll,6.05.2600.2180
Microsoft H.263 Video Codec,0x00200000,1,1,qcap.dll,6.05.2600.2180
Microsoft RLE,0x00200000,1,1,qcap.dll,6.05.2600.2180
Microsoft Video 1,0x00200000,1,1,qcap.dll,6.05.2600.2180
VP60® Simple Profile ,0x00200000,1,1,qcap.dll,6.05.2600.2180
VP61® Advanced Profile,0x00200000,1,1,qcap.dll,6.05.2600.2180
VP62® Heightened Sharpness Profile,0x00200000,1,1,qcap.dll,6.05.2600.2180
VP70® General Profile,0x00200000,1,1,qcap.dll,6.05.2600.2180
x264 - H264/AVC encoder,0x00200000,1,1,qcap.dll,6.05.2600.2180
Xvid MPEG-4 Codec,0x00200000,1,1,qcap.dll,6.05.2600.2180
Helix YV12 YUV Codec,0x00200000,1,1,qcap.dll,6.05.2600.2180
Audio Compressors:
WMA Voice Encoder DMO,0x00600800,1,1,,
WM Speech Encoder DMO,0x00600800,1,1,,
WMAudio Encoder DMO,0x00600800,1,1,,
IAC2,0x00200000,1,1,quartz.dll,6.05.2600.2905
IMA ADPCM,0x00200000,1,1,quartz.dll,6.05.2600.2905
Ogg Vorbis (mode1),0x00200000,1,1,quartz.dll,6.05.2600.2905
Ogg Vorbis (mode2),0x00200000,1,1,quartz.dll,6.05.2600.2905
Ogg Vorbis (mode3),0x00200000,1,1,quartz.dll,6.05.2600.2905
Ogg Vorbis (mode1+),0x00200000,1,1,quartz.dll,6.05.2600.2905
Ogg Vorbis (mode2+),0x00200000,1,1,quartz.dll,6.05.2600.2905
Ogg Vorbis (mode3+),0x00200000,1,1,quartz.dll,6.05.2600.2905
Microsoft ADPCM,0x00200000,1,1,quartz.dll,6.05.2600.2905
ACELP.net,0x00200000,1,1,quartz.dll,6.05.2600.2905
DSP Group TrueSpeech(TM),0x00200000,1,1,quartz.dll,6.05.2600.2905
Windows Media Audio V1,0x00200000,1,1,quartz.dll,6.05.2600.2905
Windows Media Audio V2,0x00200000,1,1,quartz.dll,6.05.2600.2905
GSM 6.10,0x00200000,1,1,quartz.dll,6.05.2600.2905
Microsoft G.723.1,0x00200000,1,1,quartz.dll,6.05.2600.2905
CCITT A-Law,0x00200000,1,1,quartz.dll,6.05.2600.2905
CCITT u-Law,0x00200000,1,1,quartz.dll,6.05.2600.2905
AC3,0x00200000,1,1,quartz.dll,6.05.2600.2905
DTS,0x00200000,1,1,quartz.dll,6.05.2600.2905
MPEG Layer-3,0x00200000,1,1,quartz.dll,6.05.2600.2905
Audio Capture Sources:
SB Audigy 2 Audio [BC00],0x00200000,0,0,qcap.dll,6.05.2600.2180
Midi Renderers:
Default MidiOut Device,0x00800000,1,0,quartz.dll,6.05.2600.2905
Microsoft GS Wavetable SW Synth,0x00200000,1,0,quartz.dll,6.05.2600.2905
SB Audigy 2 Sw Synth [BC00],0x00200000,1,0,quartz.dll,6.05.2600.2905
SB Audigy 2 Synth A [BC00],0x00200000,1,0,quartz.dll,6.05.2600.2905
SB Audigy 2 Synth B [BC00],0x00200000,1,0,quartz.dll,6.05.2600.2905
WDM Streaming Capture Devices:
SB Audigy 2 Audio [BC00],0x00200000,3,2,,5.03.2600.2180
WDM Streaming Rendering Devices:
SB Audigy 2 DirectMusic Synthesizer [BC00],0x00200000,1,1,,5.03.2600.2180
SB Audigy 2 Sw Synth [BC00],0x00200000,1,1,,5.03.2600.2180
SB Audigy 2 Synth A [BC00],0x00200000,1,1,,5.03.2600.2180
SB Audigy 2 Synth B [BC00],0x00200000,1,1,,5.03.2600.2180
BDA Rendering Filters:
BDA IP Sink,0x00200000,1,1,,5.03.2600.2180
BDA Network Providers:
Microsoft ATSC Network Provider,0x00200000,0,1,MsDvbNp.ax,6.05.2600.2180
Microsoft DVBC Network Provider,0x00200000,0,1,MsDvbNp.ax,6.05.2600.2180
Microsoft DVBS Network Provider,0x00200000,0,1,MsDvbNp.ax,6.05.2600.2180
Microsoft DVBT Network Provider,0x00200000,0,1,MsDvbNp.ax,6.05.2600.2180
BDA Transport Information Renderers:
BDA MPEG2 Transport Information Filter,0x00600000,1,0,PsisRndr.ax,6.05.2600.2180
MPEG-2 Sections and Tables,0x00600000,1,0,Mpeg2Data.ax,6.05.2600.2180
WDM Streaming Mixer Devices:
Microsoft Kernel Wave Audio Mixer,0x00000000,0,0,,
BDA CP/CA Filters:
Decrypt/Tag,0x00600000,1,0,encdec.dll,6.05.2600.2180
Encrypt/Tag,0x00200000,0,0,encdec.dll,6.05.2600.2180
XDS Codec,0x00200000,0,0,encdec.dll,6.05.2600.2180
WDM Streaming Communication Transforms:
Audio Renderers:
SB Audigy 2 Audio [BC00],0x00200000,1,0,quartz.dll,6.05.2600.2905
Default DirectSound Device,0x00800000,1,0,quartz.dll,6.05.2600.2905
Default WaveOut Device,0x00200000,1,0,quartz.dll,6.05.2600.2905
DirectSound: SB Audigy 2 Audio [BC00],0x00200000,1,0,quartz.dll,6.05.2600.2905
WDM Streaming System Devices:
SB Audigy 2 Synth A [BC00],0x00200000,10,2,,5.03.2600.2180
SB Audigy 2 Audio [BC00],0x00200000,12,2,,5.03.2600.2180
BDA Receiver Component:
BDA Slip De-Framer,0x00600000,1,1,,5.03.2600.2180
BDA MPE Filter,0x00600000,1,1,,5.03.2600.2180
You should of really put that in a code box it's like a million scrolls down..
I'd go into safe and rid the 7.8s and get back your 7.7s
I didn't realise the code feature had scroll bars on this forum! ... and I already am using my 7.7's as I mentioned in my post.
