Well the CPU and memory are fine, looks like the board.
At this point i would try to re-install window before you say its the mother board sometimes its as easy as re-installing framework.net and\or Microsoft Visual C++ at one point i had to do all three to get AMD drivers to install correct.
Also there is one last thing you can look into http://voyager8.blogspot.com/2012/04/solution-for-amd-catalyst-control.html
ok i solved the problem. here is my road map:
1- Open Safe Mode
2- Uninstall Displa Driver in Device Manager
3- Remove all AMD products (carefull it includes chipset or others too) with AMD uninstall utility
4- Set User Accoun Control in User Accounts to lowest (this may not be necessary)
5- Open in normal mode
6- Celan up registry with AVG TuneUp or some other registry cleaner
7- Download most updated driver from AMD (make sure you download right version and model)
8- When you begin installation, it extracts the files to some folder ( generally C:\\AMD\blabla.. ) Close the installer after the extraction process is done.
9- Open device manager and fina vga adapter or devce or display device or something with exclamation mark
10- Right click and show folder to driver installation
11- Show the path of the extracted files. (C:\\AMD\blabla... ) Include sub folders !
12- Driver should be installed and restart computer (resolution must be corrected this time)
13- Run the AMD driver installer again (or setup.exe in the extracted folder)
14- Select Custom NOT EXPRESS
15- Uncheck Display Driver from the list because it has already installed. Just install others like Catalyst Control Center and the others.
16- After installation is done, download and install .Net 4
17- Restart computer and open up CCC. Under the software information you should see the version that you downloaded from AMD. For example the last one is 13.3 beta.
18- Enjoy
PS: Do NOT change your motherboard or graphic card
