Micro-Cup Impingement block - work in progress
Been working on a new design. Actually, it's not that new. It arose out of an amalgamation of ideas from myself, bigben2k, jaydee116, and volenti, and this is my take on an implementation.
The design's basic approach is to utilise an array of high velocity jets (5-10 m/s) and direct them at the centre of a matching array of "cups" drilled into the copper block above the CPU die.
The jets are smaller than the cups with the idea that the jets will push to the bottom of the cup, hit the bottom and push up out the sides. The idea is that ALL of the water comes into contact with something hot and carries the heat away. Because we're using cups, there is actually a great ratio of copper-water surface area than in the fin-design that is used in the White Water. ie. in theory the concept shows promise to potentially exceed what the White Water can offer.
How about in practise? Well that depends on the implementation.
I picked up prototype #1 today. It looks like the following:
I won't go into dimensions and fine details as it's still in development and I have a second prototype block on the way. As you can see, there are a lot of very small jets and very small holes for them to focus into.
After a bit of a bad start with a bad mount and a poor lapping job done in the dark and rain, both of which were subsequently remedied, the block is finally on the test bed.
Performance is good, not quite White Water standard yet, but definitely promising. I've learned a great deal from this first go at the concept through performing various tests, and identified a number of ways in which the implementation can be improved.
Sorry for not being terribly forthcoming with greater details, but I thought you guys might be interested in what's going on."
