Yeah, it will decrease the voltage to the tube to a point below its ionization threshold and the gas will go dark immediately. The only way to controll brightness that I am aware of is to make sure you don't go below that point. They don't work like LEDs or incandescent bulbs, which will go down to nothing linearly.L337 M33P said:Cold cathodes have something like 100V inverters that run off your supply. They are designed to work with a set voltage and put out a set voltage, so decreasing the input voltage will most likely stop them working.
