After reading the "Gold Leaf for Cooling?" discussion I thought why can't you have the inside of your waterblock coated with gold, silver, platinum, what ever material is the best for transferring heat? Maybe the low heat transfer rate of water would cause it to not make a difference?
I do remember looking at a heatsink review of a bunch of different ones and there were like 3 weird fan shaped ones and the that had the best performance was coated with gold.
I'm thinking it'd cost a little over $7 to have your block gold plated because if you get your lug nuts on your car gold plated it's $7 each.
