CCC temp ramp set points?
King107s
Is there a way yet to change the temperature ramp set points for the auto fan speed mode in CCC? I know how to manually set temps but I would rather not have the 4890's screaming at 100% when I'm not putting it under load. The problem I have is that the default auto speed control low end is too low and high end of the ramp isn't high enough... Used to be able to do this with tray tools...
SeanBest
Harrisonburg, VA
You can use MSI Afterburner for something like that or flash the bios ... don't believe CCC has that type of options ... Rivatuner might do it as well...
King107s
King107s
Thats too bad because thats how I set up the PWM fan on the radiator for my cpu. I tell the mainboard software what fan speeds I want across specified temperatures.
