CD-R spindle res
cyber mouse45
Cyber Cheesiest Senior
SC
I’m thinking about making a res out of a 50 pk CD-R spindle case. Think it would work??
Sure it would.
All you need to do is find a pump that will fit inside it - unless your using an inline outside the res.
Then all you gotta do is seal it so it's water tight and modify it with hose barbs, and devise a way to fill it.
doublecheck your seals and touch up if you need to, then let her go to work :)
