CD-ROMS not responding?
Here's a link to the pic:
As for what is wrong with the drives; make sure the cables are installed correctly, and that the jumpers are set correctly. You can also try uninstalling bvoth drives and reinstalling them; that may help as well. I would also check your chipset drivers and see if you need to reinstall them.
Hope that helps! :)
