Cel 1.2 Temps
jemz0r
Hi,
Is Full Load 50C a bit too hot?
If so, which HS/Fans should I be looking for which are good value/performance.
Thanks.
Yes 50C is definitely a bit high. My load temp is 43C. What speed are you currently running also what mobo? For a good heatsink review look here http://www.overclockers.com/articles373/
Anything close to the top will cool oyur CPU nicely. Swiftech and Alpha are generally the most expensive. The rest range from $20-40 with a fan
1554@128FSB with a ST6 at 1.775v
If I try anything above that it would start giving me blue screens during XP load.
I'm thinking that it's heat that is preventing me from reaching 133FSB, which is what I really want as atm everything is underclocked.
I'm looking for something around the $20-$30US price range.
That is WAY high.
I got my 1.1a at 1.75v at a 137fsb. Just got done playing
6 hours of Q3 and UT. Have had Prime95 running about
45 min. since the gaming. CPU temp is at 36c.
Air cooled.
I'm also worried about the noise. I don't want my computer sounding like a hair dryer.
