- Mar 6, 2002
- Southern Californis
Heres a question I have sort of asked before but I still don't quite understand.
In running some theoretical numbers for memory bandwith as it pertains to the Cely-t chips with sdram. Just to keep it simple lets assume that we have a fixed fsb of 133 for all chip clockings this = 1064mhz max memory bandwith if my math is correct. Now comes the question since there are many different multipliers available from the 1.0a to the new 1.4a you can have a range of cpu speeds from 1330mhz on a 1.0a to a whopping 1862mhz with a 1.4a assumming you can actually get the chip to run at those speeds. If you divide the fixed memory speed of 1064/the various cpu clock speeds you get a bandwith efficiency ranging from around 80% with a 1.0a down to about 57% with a 1.4a chip.
At what point does all of the CPU speed go to waist because of the memory bottleneck is that not why Amd and Intel p4 chips use ddr or rdram to address this memory limitation.
I really do not see the point of extreme oc'ing beyond the memory limitations but to be honest I do not know where the point of no return is. Other than bragging rights when does it stop making sense when it comes to memory vs cpu speeds?
