First of all, appreciate all the replies.
The temp was suspect from the beggining. My Cel800@1034 used to be in low 30's. I don't think it's my cooling. Currently using Alpha Pal6035 w/ YSTech 40cfm fan /w AS3. Will have to remove everything, reapply and try again. Not really looking forward to going to the 80CFM fan, as the current one is plenty loud.
The temp of 43-46C is idle. Using CPU Burn it gets to 51-52C. The other board sensor reads 36-38. Parhaps more case cooling is in order.
The pins rapped for the Vid Mod are Vid1 & Vid2. Instructions for that were found in this forum.
The memory should not be a problem. Crucial PC133 Cas 2, 256mb x 2. Video Card GF3 Ti500. HD 60GXP 40gb x2 in Raid0 set up.
Will reapply HS/Fan, maybe put 120mm in the side over the CPU. Will keep you all posted. Till then, keep it coming.
