- Dec 18, 2000
- Germany->Bavaria-> Augsburg
Hi guys and gals,
well as you probably remember I was lucky enough to get a new Celeron 1GHz CPU, that was produced in the also new TB1-stepping and got it upto 1700 MHz(170 MHz FSB).
Well, as you can see in my sig, the chip now refuses to operate stable even at 1500 MHz!!!
But I think I know the reason why it behaves so strange
Well, I removed the IHS, because I thought it would be a god thing and would give me about 2-3 °C less on-die temp using my Thermalright SLK-800 Heatsink with Delta EHE 80CFM fan.
As it seems, in reality this wasn't such a good idea. The IHS seems to be there for a reason --> simply to spread the enormous heat away from the small die into copper of the IHS!
Now, I think at clock speeds of 1500 MHz and more, this small die of the TB1-stepping chip seems to get to hot woithout the IHS, as there's too much heat in a too small area --> crash!
Now, my thought is to reattach the IHS, but:
1) I plan to lap its downside, to make it fit perfectly on the CPU core
2) I plan to lap its upside to make the best possible conntact with my already lapped Thermalright SLK-800 heatsink
3) I plan to attach the IHS using Arctic Silver Epoxy and to fill the whole IHS's inside with it, so that there won't be any air between the CPU's ceramic and the IHS's metal, but thermal-conductive Arctic Silver Adhesive!
Do you think that this could work out fine???
And did you understand what I'm going to do?(I ask because I know that unfortunately my English isn't perfect)
