Cellphone numbers
ToiletDuck
my cellphone screen is going out and very close to dead. It is the standard Nokia older one. Is there some way that I can hook it up to my computer or other means of getting all my numbers off it?
duck
Phone here
Kendan
Senior Punk
Dark side of hell
If it has a memory chip inside and your new phoone has a slot for it you can just transfer the card. I think you can also use Nokias software to transfer the phonebook to your computer.
_slh_
Sheffield, UK
make sure all your numbers are stored on the Sim card rather than the phones internal memory. Or go out and buy a data cable.
kenkun
You can search e-bay for it.... usually ebay has some cheap datacable/software bundles. But then again, if you're getting rid of it, then it's probably not worth it.
If it has a sim chip then I would definitely just save it on there and transfer it to your new phone when you get it. You don't HAVE to keep that sim card. But just for your phone numbers.
Otherwise, start writing... if you're phone is an older standard version without a sim card, you're going to have to write it all down by hand.
Good luck! :)
_slh_
Sheffield, UK
Its a 3360, it uses a sim card. There should be an option somewhere to store all your numbers on the sim or the phone. Just make sure theyre all on the sim. Then put the sim into your new phone and, if youre planning on carrying on using the old sim, just leave it at that, or, if you have a new sim, copy the numbers from the old sim to the new phones memory, then switch the sim for the new one.
Andyman902042
indianapolis
Actually I would use a data transfer cable. Putting an old sim card in a new phone might not always work. First of all if you get a new phone from a different provider it might have a lock preventing you from using another sim card. Also putting a sim card in a new phone won't make it work right off the bat. The phones still have codes I forget exactly what they're called, like phone ID's and every time you make a call the phone company checks your ID and makes sure it's registered.
_slh_
Sheffield, UK
hes getting a new phone, whats the point of shelling out money for a data cable if hes only going to use it once? Then hed have to buy a cable to fit the new phone as well to put the numbers back on it. Try switching the sims as described above, if that doesnt work then Id either pay for the necessary cables, or start writing them down.
T
ToiletDuck
Where do i find this SIM chip at? I took the back off and all I could find to pop out was a battery.
Duck
Kendan
Senior Punk
Dark side of hell
LMAO
most of the stuff you mention will not stop him from getting the numbers off the sim and moving them to the internal memory. The stuff you mention will just not let the phone make calls;)
Duck
It should be under the battery. Some phone companies do not use the sim chip in which case you might not have one.
Andyman902042
indianapolis
Kendan said:
LMAO
Let me explain:
AFAIK the phone will not finish turning on if there is a lock. It will detect a sim card from a different provider and shut off.
That was in response to this:
I'm sorry, sometimes I worry about trying to correct others rather than answering the origional poster's question.
Kendan
Senior Punk
Dark side of hell
Andyman902042 said:
Let me explain:
but, where does he say he is switching providers?
