- Jan 24, 2006
- South Dakota
Hi guys,
As you may be aware I have worked out how to sync ldap and samba on Ubuntu. Everything works great from an Ubuntu machine. When a user changes their password it ripples through the network syncing the passwords with LDAP and samba.
However when I try to reproduce this with CentOS I can't or at least not exactly. When I issue the 'passwd' command it will indeed change the LDAP login but not the samba password on the CentOS server.
However, if I use 'smbpasswd' it changes both LDAP and SMB passwords successfully. Obviously not ideal. There is no error in any of the logs during the time period I try to change a password. I even turned up the logging to 5. Here is the CentOS smb.conf
Here is the Ubuntu config (almost identical)
If this was a pam issue wouldn't I see errors in some log somewhere? Anyone have any pointers?
Code:
[global]
workgroup = STRATUS.LOCAL
#security = domain
security = user
passdb backend = ldapsam:ldap://ds.stratus.local
passwd program = /usr/bin/passwd %u
ldap admin dn = cn=Directory Manager
ldap suffix = dc=stratus,dc=local
ldap user suffix = ou=People
ldap machine suffix = ou=Computers
ldap group suffix = ou=Groups
ldap ssl = start tls
log level = 5
log file = /var/log/%m.log
unix password sync = yes
ldap password sync = yes
pam password change = yes
socket options = TCP_NODELAY SO_RCVBUF=8192 SO_SNDBUF=8192
os level = 33
domain logons = yes
template shell = /bin/false
load printers = no
printing = bsd
printcap name = /dev/null
disable spoolss = yes
passwd program = /usr/bin/passwd '%u'
Code:
[global]
security = domain
passdb backend = ldapsam:ldap://192.168.99.90
ldap ssl = off
os level = 33
domain logons = yes
