Change BIOS Setting from IDE to RAID...
Kivin
... Presuming I make this change, will I be required to surrender the data I have stored on my hard disks... the ones that are not included in a RAID 0/1 setup?
The actual setup is:
2x 1TB in Matrix RAID (100 GB RAID 0, ~800 GB RAID 1)
1x 500 GB
1x 320 GB
etc.
I'm interested in the data on the 500, 320, et al.
Thanks much.
K
Kivin
Thanks mate, you're definitely right. RAIDed my drives and it's absolutely outstanding. Vista install from the cd key prompt to desktop under ten minutes!
