change priority of running processes?
Christoph
JAPH Senior
Redmond, WA
I've noticed that Opera 6.01b1 eats up about 10-15% of my CPU cycles when I leave it doing nothing. Is there some program I can use to raise my Folding client's priority or lower Opera's when I'm not using it?
i am just a linux newbie...
but the "nice" command lets you set the priority of any process running...
The "ps" command will give you a list of the processes......
"ps -l " will list all processes, and give you the priority that they are runnign with.... (under the PRI) colum)
If you could assign a higher number to it, then it sould have a lower prority....
"nice <command to lauch opera>" and that should add a value of 10 to decress the priority of Opera (by 10), or "nice -n <command to lauch opera> " were n is a number you chose.
Will this work?
I am not 100% sure, but it may be worth a try.
Like i said before, justa linux newbie myself
renice will let you change the priority of a running process. Read the man page for renice.
Oh yeah. The man pages. Thanks.
Edit: I've got it now. Some page I had loaded had a flash ad that was eating up my cycles. I closed the page, and now Opera's happily running on 1.3-1.85% of my cycles, even with a higher priority than the folding client.
Thanks!
