Hey, so I know this isn't completely sound, but I felt like it fits this category best. Essentially, I've been having problems with my graphics lately, and I'd heard you can sometimes fix it by changing PCI slots. So, I tried this, and as far as I can tell, it fixed the graphic problem - I can get more into the graphic problem if need be.
Unfortunately, after I moved the card to a different slot, my sound doesn't work. It won't play through speakers, or headset. Headset you can hear your voice when you talk into it, and the speakers still hiss when turned all the way up, as well as they kind of pop (the kind of pop that you hear when you plug and unplug headphones into the audio jack), at a very specific pace - [pop] [short pause] [pop] [long pause] [pop] [short pause] [pop], or pop pop, pause, pop pop.
I've seen a couple suggested fixes for this problem. First, go to control panel, sound and make sure that it isn't set to AMD (or ATI) HDMI Output, and that it is set to Sound Card (or Speakers). Everything is in order there. It was never changed from "Speakers" which is the input it is normally set to.
Second fix is go into BIOS and enable the onboard audio device. Unfortunately, I can't find anything about this. In ASUS UEFI BIOS Utility, I go to "advanced mode", then the "advanced" tab, then "onboard devices configuration".
Inside that you have:
VIA 1394 Controller [enabled]
JMB Storage Controller [enabled]
JMB Storage OPROM [enabled]
Display OptionRom in POST [enabled]
Asmedia USB 3.0 Controller [enabled]
Asmedia USB 3.0 Battery Charging Support [disabled]
Realtek LAN Controller [enabled]
Realtek PXE OPROM [disabled]
S3 Video Deposit [disabled]
Then below that I have two menu options:
Serial Port Configuration
SB HD Azalia Configuration
In Serial Port Configuration:
Serial Port [enabled]
Change settings [I0=3F8h; IRQ =4]
In SB HD Azalia Configuration:
HD Audio Azalia Device [enabled]
Azalia Front Panel [HD]
SPDIF Out Type [SPDIF]
And now I'm actually having even more problems with the sound. Instead of my computer constantly saying that it's going through the speakers, now it's changing (again, at specific intervals [seemingly the same intervals as the popping sound I mentioned previously]) between being set to speakers, and saying the speakers aren't plugged in.
If anyone has any idea about this, the help would be greatly appreciated. Just let me know if you need any more information, or any screenshots, pics, etc. Thanks.
