changing fsb on 2500 barton
jamdevo
:( i am running with 2500 barton ,xp pro,gfx 5600.i changed my fsb to 200 mghs and was delighted to see at start up my cpu read as 3200,but then windows wouldnt start becuase of an error with some sys root file missing .but when changed my fsb back ok. why.please excuse me i am a novice as you can see .i have Shuttle AN35 NF2 Ultra board and 1024 2700 mem.
jonspd
Super Speedy Senior
You may need to also increase the vcore or something hard to say without some system spec's to go by. Also it could be you mem, cpu overheating, psu etc etc.
J
jamdevo
thanks jonspd ihave 2500barton,shuttle AN35 NF2 ultra,1024/2700 mem,128 GFX 5600,XP Pro.
mustrum
It's most likely your memory then. 2700 mem isn't supposed to run at 200 fsb.
Increasing Memory Voltage to 2.8 volts might help.
J
jamdevo
Thanks,have been playing around,but am worried.have changed "multiplier?" to x11,"ram voltage?" to 2.7,and fsb to 175(from 166).am now reporting 1933mghz(from1833mghz),started up ok,after start up cpu temp reading 48c (from around 31c, i think) is this a worry. what is "test under load" and how do i do this.sorry i a a complete novice and hope i have`nt messed up my computer.also have played thief 3 since changes and seemed to be OK
mustrum
You seem to have 48 degrees idle. That's too high. Your system will get unstable under extreme conditions. You can test max load with the tool prime95. Run the torture test for maximum heat for at least an hour.
You might have to buy a new CPU cooler or optimize your case cooling.
