Sadly, just after receiving my new 1.4GHZ Thunderbird, my motherboard died on me (Well, it didn't actually die, I damaged a trace directly beneath the socket lug while installing the heatsink). It was an MSI K7T-Turbo-R. I had 2 40GB hard drives in RAID-0, and now that I no longer have a working motherboard, I am in need of a replacement. My main question is this: Can I use my existing hard drive array on another motherboard, if the motherboard uses a different RAID controller (was strongly considering a KK266-R), or do I have to disassemble the array using the same chipset it was created with, in which case, I would probably get another K7T-Turbo-R/Limited. Does setting up hard drives to run in RAID-0 change anything physical in the drive, or are they usable after being formatted/partitioned with another kind of controller. Any help/advice would be appreciated. Thank you.
The array was also paritioned into 4, 20GB drives if that will make a difference.
