Cheap Dual Mobo for Folding
Gandalf
Near Niagara Falls, CANADA
Alright, I have a question for you people with experience with Dual motherboards.
I need a cheap dual mobo that can be overclocked and also support an XP chip.
Any advice will be usefull.
DaveB
Senior Member
No such thing. All dual AMD mobos are expensive starting a $175 for the Tyan S2460.
Gandalf
Gandalf
Would it be cheaper to just go with 2 seprate rigs?
What is a cheap single chip motherboard that is good for a little overclocking?
SDRAM or DDR since it is just folding.
flounder43
Senior Lawyer-clocker
Minneapolis
ECS K7S5A, that is your answer. They use either SDRAM or DDR. Plus, built in LAN.
DaveB
Senior Member
That ECS board is useless for overclocking. I had my Shuttle AK31 running an Athlon 1.4 @ 1.65 GHz and an XP 1800+ @ 1.725 GHz. And these were 100% stable speeds. I could run the XP 1800+ as high as 1.772 GHz but it had some stability issues so you wouldn't want to go that high.
flounder43
Minneapolis
I disagree. I ran a Duron [email protected] for 2 months on that mobo. There is no multilper overclocking, but with the right bios, fsb overclocking is good, and people have been very happy with the results...
res0r9lm
florida
I disagree dually is the cheapest way to go. the board might be more but you make that up with not having to buy extra ram, video card, hard drive, nic, cables, case, ect..
