- Nov 2, 2003
Before I built my computer, I started looking into making a quiet computer. I cut the fan grills off my case, and looked at buying some fan gaskets. It makes sence, less vibration. After looking at the gaskets on the market, I came up with a cheaper way to do it.
Buy a bike innertube! if you cut it, you have about 1/16 of an inch of gasket! (there is usually a powder inside, I do not know if it is conductive or not, so clean that off). You can cut an x shape in the rubber, and hand start your screws, adjust them to fit as you tighten them.
I have 3 80mm case fans running, and the m/b and video card add 4 more fans (including the cpu) and my computer is noticably quieter than my friends, who only has one case fan!
E
E
