- Jan 17, 2005
- Lörrach Germany
Hey guys,
I want to build a cheap gaming photshop surfing PC with as much bang for the buck as possible. After a long time on the internet i came to the following two configurations(I live in germany so price is in€):
PC1:
CPU: E8200 120€
RAM: G.Skill DIMM Kit 4GB DDR-1000 67€
Cooling: Thermalright SI-128 SE 34€
PC2:
CPU: Q6600 120€
RAM: TeamGroup Elite DIMM Kit 4GB 55€
Cooling: Water??? ca.80€
The E8200 should go up to 4ghz and i hope and wnat to go for a 3,6-3,8ghz 24/7 setting. The Q6600 is more of a problem with heat I hope the watercooling fits.
Question1: Anyone has an idea on a different cooling solution for both versions? The limiting factor is the height it´s 120mm in total minus 10-20 for MOBO and CPU so 100mm max for the cooling solution.
PC1 and PC2:
MOBO: either Gigabyte GA-Q35M-S2 76€ or Gigabyte GA-G33M-S2L 60€ Question2: Is the Q35 worth the extra cash for better OC(i heard if internal graphics disabled it performs like a p35 chipset)?
GPU: any suggestions welcome. I have trouble with this one i just dont know what to do it got to be small because of m-atx but it also got to be powerfull.
I want to be able to play crysis with high detail!
CASE: LC-Power 2039MB 40€ any suggestions on an other case?
Question3: Is 380Watt from the case enough for a Q6600? because there is no way to upgrade this component or only at unreasonable prices.
So what do you guys think is this possible at all?
Thanks,
Jakob
PC1:
CPU: E8200 120€
PC2:
CPU: Q6600 120€
PC1 and PC2:
Thanks,
Jakob
