Checking and changing IRQ?
Wildfire
Surrey
How do I find out where all my IRQs are assigned and how do I change them? I am only wondering as I was readoing the previous thread about under performing GeForce 4s and mine will be arriving in a few days and I do run XP Pro.
Thanks
you can use SANDRA for this look under Hardware IRQ settings
i hope this helps
you can also go to system information. In XP it is located
Start/All Programs\Accesories\System Tools\System Information
Once there look around and you should find what you need. Good Luck!
