- Aug 31, 2013
Hi guys, I posted years back for a while under a different name when I was building computers. I haven't built one in years, but I always appreciated everyone's input, so I'm back because I found myself in a bit of a conundrum.
About how long should I expect a disc scan of an external 2TB HDD (USB) to take?
What happens if you have to stop it in the middle of the scan?
My Dell xps 9100 (desktop) got a BSOD requiring resetting the computer.... in the middle of me sorting files on my external HDD (connected via USB). (Thank God I wasn't transferring anything at the time!) there are some irreplaceable files on it.
To ensure there wasn't any damage, I used my laptop to look at the HDD, and the "might have errors so do you want to check?" prompt came up. To be comprehensive, I selected "automatically fix file system errors" and "scan for and attempt recovery of bad sectors." Then I realized I'd perhaps made a mistake by doing that, losing many hours of computer availability because it has taken 7.5 hours to go through 210,000 files. I have a ton of files (drive is maybe 80% full) and it looks like that is maybe only 10% of the total, by the progress bar. Laptop is at maximum performance, but it's a Latitude 6410 so it isn't a powerhouse.
I don't want to move it if I don't have to, but can't wait for days because I will need the laptop eventually.
But there is some irreplaceable data on that HDD! That is priority. And there might be a storm tomorrow. That'd be worse than what's already happened.
What happens if you stop a scan? Is there a risk damaging anything?
What do you recommend doing? >___<
