China Launches HDMI and DisplayPoert Alternative: Meet the GPMI Connector
EarthDog
Gulper Nozzle Co-Owner
Cbus!
From Tom's (among other places).
The Shenzhen 8K UHD Video Industry Cooperation Alliance, a group made up of more than 50 Chinese companies, just released a new wired media communication standard called the General Purpose Media Interface or GPMI. This standard was developed to support 8K and reduce the number of cables required to stream data and power from one device to another. According to HKEPC, the GPMI cable comes in two flavors — a Type-B that seems to have a proprietary connector and a Type-C that is compatible with the USB-C standard.
Because 8K has four times the number of pixels of 4K and 16 times more pixels than 1080p resolution, it means that GPMI is built to carry a lot more data than other current standards. There are other variables that can impact required bandwidth, of course, such as color depth and refresh rate. The GPMI Type-C connector is set to have a maximum bandwidth of 96 Gbps and deliver 240 watts of power. This is more than double the 40 Gbps data limit of USB4 and Thunderbolt 4, allowing you to transmit more data on the cable. However, it has the same power limit as that of the latest USB Type-C connector using the Extended Power Range (EPR) standard.
Not sure if it will gain any traction, but, it's nice to see more capable cabling.
