chipped cpu
Railskinner
well that isn't good news for me then, it all started by buying a swiftech mc462-a and finding out that it doesn't fit onto a asus a7a266 motherboard. i had to take off the superorb ot see if it would fit. i was told by swifttech and the place that i purchased the hsf from that it would fit this motherboard. if i would have known this would not fit i would not be out a axia 1.333 t bird.i wonder if i can go after either swifttec or the place that i purchased the hsf from?
Aman99
Proper installation of Swiftech coolers should never chip cores, what sounds more likely to have happened, is that you chipped it when you removed your SuperOrb. I would place my bet that that is what happened.
Aaron
