Chipset and other temps
Tacoman667
Kingwood, TX
What is the IDEAL temp for the chipset and PSU? I know the ideal ones for the CPU but not too sure on these others. When I mean ideal temp, I mean without a pelt/water block on the damn things. No totally outrageous temps, just a good solid average temp that I could shoot for without spending 1000's of dollars on a damn vapochill or something. Thanks all!
kat
Senior Member
belding,MI,United States
lower is better my friend... how low can you go??...if your pc is still running then its not to high
cooling is the key . and if your key is a big one ... then you will do fine
can do kat!! ;D
