- Apr 21, 2001
- OH-Heartland of the USA
Here's one for someone to ponder. I have been trying to get past the 1 gig mark with my Duron700 without the temp going over 50c. Well, I'm almost there. I found an old 486 cpu HSF and took the fan off and mounted it to the top of the VIA Vt8363 heatsink. I notice that this chip also controls the agp and PC133 memory. Now I am running [email protected], [email protected] and [email protected]. Temp is steady at 51c on the CPU.
I had touched the heatsink on this chip several time lately and it is always just slightly warm. My next step will be to remove it from the chip and apply some thermal grease and maybe try a little higher FSB. Also plan to cut a hole in the mainboard mounting plate behind both this chip and the CPU socket. I figure it can't be cooling it very much but if that is all it takes to get to FSB=110 then I'll try. My previous attempts at getting to 107 resulted in no POST.
Anyone else try this??
Above w/(BALANCED)FOP-32, 256meg Kingston Value Ram(Got cas2 Crutial on the way)
105x9.5 just ain't enough!!
