Choice
Bman1238
Disabled
arizona
It all really depends on your price limit is. With the R9800pro, you would get faster speeds and slightly better image quality. If money isn't an issue, I would say go for the 9800pro. as for your CPU, a Barton 2500+ would go nicely in your system. I've played around with on of those before and got it up to 2.3GHz with the Thermaltake volcano 11. For the RAM upgrade, if you have less than 512mb, i would suggest upgrading to 512mb. Also, if you run your memory at a syncronous clock with the fsb, you will get better memory performance.
:sn:
water_cooler 20
water_cooler 20
FL, USA
Will my cpu and RAM be a bottle neck to the R9800 W/ 256 VRAM
RAM=256:rolleyes:
and what ever card i get i will be cooling it w/ chilled water and a TEC.
Oni
Oni-ni-Kanab;, Ninja Hippo eater Moderator
St. Catharines, Ontario Canada
Well, your RAM will hold you back at any rate. It's cheep now, so burn a bit to upgrade that, then burn the rest on a 9700 Pro and overclock it.
deathstar13
FSB FRIEK
well i know the cpu is fine.
depending on the fsb your getting now and the amount of ram you have now.
if your doing 200fsb and have 512mb get the 9800pro 256mb card
if lower than that upgrade the box first and get a 9700pro
