- Jun 22, 2001
- Azores - Mid-Atlantic
I'm and intel guy, this is the frist time getting a amd system
I have these 3 bundles in mind, and i'll get one of these but before getting it i'd like to know what you guys think about these bundles, and for u witch one of these will be the perfect choise to a system with stability, good oc potential, "fast has hell", extreme gaming possibilities, fast and nice mpeg2 enconding...etc.
Abit KR7A-RAID/AMD Athlon XP 2000/Coolermaster HHC-001 Super Heatpipe - Bundle
Abit has done it again with the KR7A-RAID, while not the quickest onto the market it is surely the best for overclocking, overall speed and yes, even reliability. Using the same VIA KT266A chipset found in the Epox 8KHA+ and Asus A7V266-E the Abit KR7A is pushing the boundaries even further
Featuring :
» 4 x 184pin DDR-SDRAM slots (3 if using standard unbuffered DDR-SDRAM)
» 6 x PCI slots
» 1 x AGP (4x) slot
» 4 x IDE Busmaster (UDMA100) devices
» 4 x IDE Busmaster (UDMA133 RAID 0/1) devices
AMD Athlon XP 2000+ and Coolermaster HHC-001 Super Heat Pipe.
Abit KR7A-133/AMD Athlon XP 2000/Coolermaster HHC-001 Super Heat Pipe - Bundle
An evolutionary rather than revolutionary upgrade the KR7A-133 uses the VIA VT8233A southbridge to provide onboard UDMA133 support.
Featuring :
» 6 x PCI slots
» 1 x AGP (4x) slot
» 4 x IDE Busmaster (UDMA133) devices
AMD Athlon XP 2000+ and the Coolermaster HHC-001 Super Heat Pipe.
Asus A7V266-E/AMD Athlon XP 1800+/Taisol CGK760092 - Bundle
Using VIA's latest KT266a chipset the ASUS A7V266-E has official support for AMD's latest Athlon-XP CPU's and allows multiplier, FSB and voltage adjustment through jumpers or BIOS softmenu.
Featuring :
» 3 x 184pin DDR-SDRAM slots
» 5 x PCI slots
» 1 x ACR slot (Advanced Communications Riser)
» AGP Pro (4x) slot
» UDMA100 IDE
» 6 x USB slots supported (4 supplied)
AMD Athlon XP 1800+ processor and the Taisol CGK760092 heatsink, provided with a sachet of thermal compound.
Thanks
Featuring :
» 6 x PCI slots
» 1 x AGP (4x) slot
Featuring :
» 6 x PCI slots
» 1 x AGP (4x) slot
Featuring :
» 5 x PCI slots
» AGP Pro (4x) slot
» UDMA100 IDE
Thanks
